Question about Dell 0Y3740 Keyboard
Certain keys dont give the correct character when pressed.when @ is selected i get"""
    President:
  • 2,049 Answers
Pressing alt + Shift toggles between American and English keyboard layout.
Give it a try...this should make your keboard revert back to normal.
Posted on Nov 16, 2009
    President:
  • 1,185 Answers
If you are in the USA you have it set as a UK Keyboard.
Or visa versa
Go to Control panel , Keyboards and select the correct setup and region
  • Tom
    Tom Nov 17, 2009
    I would not get carried away with the thanks bit
    Did you expect one of us to come over and do it for you ?
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Keyboard typing multiple letters/ numbers when pressing certain keys.
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard's repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
Feb 03, 2013 | Computers & Internet
Extra characters display when key pressed
Check the NumLock Key. If your keyboard isn't typing the correct characters, you may have the incorrect input language selected. Many laptops will convert most of the keyboard into a number pad if NumLock is enabled. Press Num Lock + Function or Function then NumLock to make sure its disabled.
Cheers!
J the Guru
Aug 12, 2017 | Microsoft Visual FoxPro Professional...
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
Jan 11, 2009 | Brother IntelliFAX 4100 Laser Fax
IBM Wheelwriter 3 typing incorrect characters
If you have another printwheel try that, if you still have the trouble try blowing out the area where it is in stalled. If that fails turn the machine off then back on, after it completes the POR mark the printwheel with some white out, repeat the POR see if the mark is in the same place, if it isin't you probably have a selection plate problem.
DickyO
Nov 11, 2008 | Lexmark Wheelwriter 3 Typewriter
I'm stuck on lego star wars 2
Press L or select (dont remember which) when you are near the character you are by. The will become your partner. Then press L/select on your partner and you will become that character. (if I remember correctly.)
Oct 05, 2008 | Video Game Consoles & Games
Wrong keys printing
I have sent you the manual
Please could you rate my response
Many Thanks - Regards
TC
Aug 19, 2008 | Brother GX-6750 Typewriter
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
Keyboard problems
dear bangaloreboy , this may be due to your shift key is having a problem. This is permanently pressed or the other key is having some problem . If you think shift key is not causing a problem please check the key board settings from contol pannel .
I donot think this is caused by changing the operating system.
Best Regards
rafique
Feb 25, 2008 | Computers & Internet
CHR SIZE AUTO?
Press the Return button and the machine will automatically print the size the tape will allow! :) Title:
What does the error message "CHR SIZE AUTO?" mean? Description:This message appears when the selected character size is too large for the width of the tape cassette installed.
You have the following options:
  • Press the "Print" or "Return" key to allow the P-touch machine to automatically select the maximum character size that fits the tape width.
  • Press the "BS" key to clear the message, and then install a wider tape cassette.
  • Press the "BS" key to clear the message, and then select a smaller character size by following these steps:
    1. While holding the "Code" key, press the "Size" key. The display will show the current character size.
    2. Keep the "Code" key held, and press the "Size" key until the desired size is displayed.
      If you select "AUTO", the P-touch machine will automatically adjust the character size to the largest possible size.
    3. Release the "Code" to apply the setting.
If you have the correct size tape installed and still get the error message, please try removing the cassette from the machine and reinstalling it. Also, check that the tape cassette is seated firmly in the compartment.
Note
    The following table shows the maximum character size that can be used with each tape width.
    Tape Width Maximum Character Size 1/4" (6 mm) 12 points 3/8" (9 mm) 18 points 1/2" (12 mm) 24 points 3/4" (18 mm) 42 points
Related Models PT-1900
Feb 17, 2008 | Brother P-Touch 1900 Label Printer
Dell 0Y3740 Keyboard Logo
195 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
