Question about Logitech Rumblepad 2 Game Pad
I try to use on need for speed shift and it don't work
    Sniper:
  • 64 Answers
Hmmmmmm! it must b damage!! or sm other problem!!! do replace ur remote !!!
Posted on Nov 16, 2009
    Scholar:
  • 100 Answers
I am replying late but if you still want to play NFS Shift with your Rumblepad 2 go here and download the profile. It includes instructions on how to set it up:
http://bit.ly/Logitech-Gamepad-Profiles
Hope that helps.
Posted on Nov 12, 2012
Tranmission won't into shift into D stays in 2nd. gear speed odmetor don;t work
Hi...sounds like you need to have your 3-2 shift solenoid in the transmission replaced. Go to a local Auto Zone auto parts store near you and ask them to check you computer codes to see if this solenoid shows up. They do not charge for this service.
Sep 17, 2011 | 1999 Dodge Grand Caravan
My transmission will not shift out of second gear. I've changed the filter for the transmission twice. I also changed the fluid and it hasn't helped. I don't believe that the transmission...
Have you checked to see if the linkage is adjusted correctly? If the linkage is okay, I'm hoping it's gunk stuck inside the valve body or other component.
My old fix,tried and true, is to add one and a half cans of `Sea-Foam' TRANSMISSION TREATMENT to a large transmission(10 qt. capacity or more).
By following the directions on the can and running the ****** thru its paces, it might start working for you. don-ohio
Sep 14, 2011 | Chevrolet Tahoe Cars & Trucks
Wont shift out of first...will shift to second if you do it manually. Parking lights work but lower brake lights and flashers don't work....all fuses are good
If both sides of the lights does not work then it just may be a bad relay.
As for the shifting issue it could be an issue with the PCM of the car or the solenoid itself or just the velocity sensor. I would suggest first to have a scanner connected to the PCM to retrieve error codes that may be saved. Some shops would let you borrow their scanner. This is to avoid unnecessary removal of the transmission. The codes can help pinpoint where the problem was detected.
Jun 24, 2011 | Chevrolet Tahoe Cars & Trucks
I have a Bolen lawntractor and it stays in first gear only,it will also go in reverse. I know the belts are not slipping because I put it up to a tree and the wheels spin. I see a rod that goes to the...
It sounds to me that you are expecting this machine to shift thru the gears like an automobile manual or automatic. I believe your machine is working just fine. When you shift into a gear the machine is designed to stay in that gear till you stop, shift into another gear for desired speed, sloww or fast. Try this , I think you will see what I mean. GOOD LUCK.
Jun 17, 2011 | Garden
2000 yr.isuzu 250 kb diesel has a noise coming from gearbox area when moving into 5th gear
Its a manual trans right? Those are probably worn syn rings in the transmission, or a loose throw out bearing on the clutch. but if it was a throw out bearing it should be happening in all gears. So its probably worn sync rings in the trans. this means you need your trans rebuilt. go to a local trans shop. to make it shift easier for now, try to match the speed of the car with the speed of the engine. what i mean is when upshifting to 5th gear, wait for a sec til the engine drops in rpms to shift (wait til the rpms are they would be right after you shift into gear). This will allow you to shift without syncs, and make it an easier shift. don't worry its easier then it sounds. but best to get it fixed
May 04, 2011 | Isuzu Pickup Cars & Trucks
Is the speed sensor being messed up why my transmission wont shift
Nissans have been known to have tranny shifting problems caused by a bad speed sensor.
Apr 24, 2011 | 2002 Nissan Altima
I have a 1995 gmc sonoma and it won`t shift from first gear and the speedometer don`t work
You may have a bad Vehicle Speed Sensor [VSS] This sensor provides the information the speedometer needs to indicate speed and also supplies the transmission with information it needs to determine when to shift. If the signal is lost you can end up with the very symptoms you are having. It's usually located on the rear of the transmission or transfer case area. Hope this helps!
Nov 27, 2010 | GMC Sonoma Cars & Trucks
When I first start driving the transmission work fine ,then when I slow down it shifts into 2nd. and won't shift up again. So i stop the car , start it again and then it shifts fine again until I slow down...
I was told by a Chrysler tech that it's the shift solenoid located in the trans. pan. There are 4 of them and you have to have it checked to see which one. You don't want to replace all 4. About $80.00 at a dealer! Mine does the same thing. 2004 Concorde lxi.
Nov 21, 2010 | 2000 Chrysler Concorde
1993 Ford Escort 4 Door Byockey830
speed sensor is only used to tell the processor to shift the trans into overdrive and lock up torque converter, don' know what the orig post was, try to always use the same thread to post new questions about the same issue.
Mar 08, 2009 | 1993 Ford Escort 4 Door
Logitech Rumblepad 2 Game Pad Logo
431 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
