Question about Olevia LT42HVi 42 in. LCD Television
My tv shuts off at random times and when I turn it on again the color is messed up.
New power board
Posted on Oct 27, 2011
  • 3,741 Answers
Tv turning off automatically
for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv power led comes but no picture comes up..in this case the circuit board needs to be checked with a multimeter.the faulty and burned out component part should be detected and then should be replaced with the help of soldering iron.to make it proper.to avoid further damage i suggest you that do not on the tv again and again as it will short some more tiny components and the reparing cost will increase as per that.at present its the normal circuit short problem in the tv get it repaired before using the tv again.
Posted on Nov 16, 2009
Magnavox 46" LCD TV shuts itself off after a random amount of time.
Is there a person in your environs who is mischievous or prone to malfeasance? Someone may be using a TV-B-Gone on you. Check this out:
https://cornfieldelectronics.com/tvbgone/tvbg.home.php
Apr 14, 2014 | Magnavox 46mf401b/f7 46 Hdtv, Lcd 1080p...
Computer screen going staticky randomly during use, bright flashing colors.
Do a hard disk check. I would bet your hard drive is going on you. Make sure you back up everything. The other thing to check is your video card. Much easier to deal with on a tower than a laptop.
Jan 29, 2014 | Dell E228WFP LCD Monitor
Shut off tv on its own
Look into getting a new Power Supply Board. There is a good chance that you have 1 or more faulty capacitors on the PSB.
Apr 03, 2009 | Samsung HLN5065W 50" Rear Projection...
Color wheel
could be a jumper on the DMD board that must be removed, look for a small sticker that points to the jumper, or it could be a setting in the factory mode, mute-182-power will get you in there, check the settings for the color wheel
Jul 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
TV turned off and wont come back
looks like the color wheel its bad in the set,color wheel its not spining at its proper speed( one of the segments may be broken)
thats the vibration you are hearing.. and the set its trying to turn on..until you replace the wheel you will be able to watch tv again.
hdtvman
Jul 03, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Random turn off
just soldering your color ic or your RGB ic
Jun 20, 2008 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
Samsung pcj522r shuts off randomly
samsungs have convergence ic that heat up and cause tv to shut off but most of the time the colors will be off. Alsp solder connections could cause this on voltage regulators.my guess would be convergence ics cost for repair is 250.00
thanks doctor video
May 12, 2008 | Samsung PCJ522R 52" Rear Projection...
Turns off randomly
mine does also does yours click at random times and the screen goes out in small places for a split second?
Apr 02, 2008 | JVC AV-32020 32" TV
Sony kv27v22 TV
check horizontal drive tramformer for intermitance is common problem some time blows horiz transistor to or vertical IC intermintence to
Apr 01, 2008 | Sony KV-27V22 TV
Olevia LT42HVi 42 in. LCD Television Logo
136 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
