Question about Craftsman Garden
I have a problem because my kohler motor have a gas leak and when i retire my spark plug the gas leak of there
Is the fuel solenoid operating correctly? Check on carby.
Posted on Nov 17, 2009
Kohler 15 hp motor turns over but will not run.what is wrong?
take the spark plug out and turn the engine over to blow out any excess gas in the chamber. put in a new spark plug and try again. if this don't work you may have a valve or timing problem. there are many videos that show how to check valve clearance and flywheel key on you tube. if you have gas and spark and compression it should start.
Mar 31, 2018 | HP Garden
How to change the spark plug on a Husqvarna 6021P 21 inch
I use a spark plug wrench or a deep socket and turn counter clockwise.
Jun 16, 2014 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Spark plug smells like gas
I think we're missing a lot of info. or it's posted wrong! Is it because it will not run? What else is it exhibiting for a problem? I'm assuming you may have a Kohler motor in it, is the fuel tank level dropping in it while it's sitting? Get back to us with what caused you to tell us Spark Plug smells like gas.
Nov 23, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Kohler command 20 twin engine - no spark
If there's no spark, then either the spark plug has come into contact with gas, or the ignition coil is bad. Try either replacing the spark plugs, or removing the old ones and seeing if the tips are damp.
If replacing them doesn't work or the plugs are dry, then try replacing the ignition coil.
Feb 15, 2013 | Kohler 20 Hp OHV Command V-Twin Engine...
Husqvarna 6021p won't start
Make sure spark plug wire is connected and that plug is not blackened and fouled out. Also check your fuel filter (plugged?), the handbar safety lever & it pull cable and make sure it is opening the breather assembly down at the motor or closing the proper switch (unsure of the setup) Those are typically the most common problems. Good Luck
Jun 07, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
20 hp kohler leaking gas out front right side of motor
Check all your fuel hoses make sure they are not broken or any holes are in the lines themselves. Also clean out the Carb and all the ports leading to the engine with some carb cleaner. If you still have raw fuel leaking then you are going to have to replace the top gasket on the motor where your cylinders are located.
May 05, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Garden Logo
128 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
