Question about Polaroid FXM-1911C 19 in. LCD Television
Tv plasma polaroid buzzing loudly when muted disappears, the volume works perfect but very loud buzzing/squeaking sound in back groud helpppppp
    Problem Solver:
  • 7 Answers
Probably the speakers are broken. Try here to get the right part
polaroid tv parts
Posted on May 31, 2010
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
Apr 26, 2012 | Hitachi P42H401 42 in. Plasma HDTV
A buzzing noise coming from inside the tv but still buzzes when on mute but doesnt buzz when tv guide is up on the screen or when a channel is showing what time it starts
plasma tvs buzz a lot, depending on screen brightness. its probably normal but if you can hear loudly over your volume, may be a bad board or plasma panel. from behind tv, left side = y board, right side = z board, middle = power board ---- bad panel can buzz from anywhere... if you hear all parts buzzing, its probably normal plasma noise
Jun 01, 2010 | Samsung Televison & Video
Buzzing sound + Tv picture is very weird.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS.. AND ALSO ALL FUSES AROUND IT .THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE.
GOOD LUCK
May 23, 2010 | Polaroid TLA-01911C TV
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Alesis M1 active 620 woofer problem
There clearly is a fault in the sub's amp section. It's probably the main part that does most of the work. It will need to be replaced.
Mar 07, 2017 | Alesis M1-Active MkII Main / Stereo...
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
Have a polaroid tv, model 3700 seriel F0600181940001053. WATCHING THE OTHER NITE AND A LOUD SQUEAL CAME ON AND THE PICTURE WENT OUT, TURN IT BACK ON TODAY AND THE SQUEAL IS STILL THERE WITH NO PICTURE..NO...
I have a flat screen polaroid lcd hdtv model 3700, first the sound started to get really loud with a beeeeeeeeep when we turned on and after a while was gone, now it doesnt! we had to put mute and connect the tv to a sorround system to hear it without that crazy noise, and now the colors of the tv are gone too its just black and white when we try to see the dish satelite but if we put a movie on the dvd player colors are perfect we try to conect the ps3 player too but its black and white too. Help what can it be!!!!????
Nov 14, 2008 | Televison & Video
Polaroid FLM-323B HDTV Loud Buzzing
Hi.
If your happy to remove the back casing of the the TV set.
Lay set face down on table with several towells laid out flat under it.
Undo all screws holding back on & lift it off you may need to remove tv stand to remove back.
Once back is off either locate speakers & unplug the leads from them remember to insulate the loose wires & tie them up out of the way.
Or trace wires from speakers to there plugs & sockets on main Pcb & unplug them & thats it.
Screw rear of set back on & ensure volume is set low or at zero.
http://dysonmanuals.llc.nu/
Jul 13, 2008 | Polaroid FLM-323B Television
Loud Buzzing Sound - Rear of TV
It is probably the color wheel that needs replacing.
Oct 05, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Polaroid FXM-1911C 19 in. LCD Television Logo
206 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
