Question about Tecnik TKC1285 Dual Fuel (Electric and Gas) Kitchen Range
TECNIK TOP STOVE
THE IGNITION ON MY TOP (HOBS) HAS SUDDENLY BECOME STUCK AND CONTINUALLY CLICKS! ANY IDEAS HOW I CAN STOP THIS?
  • murf768 Jan 09, 2008
    model number 3072
Although not with a Tecnik, I have found that if you unplug the stove from the wall and let it "set" for a day or so, it gets out of this repeat clicking mode. Sometimes doing it twice.
Posted on Jul 12, 2008
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
JGBS20BEW2AD, the stove top four cooking burner constantly clicks.
The igniter switch(s) has most likely failed shorted. Fairly common with gas ranges with spark ignition.
Mar 06, 2012 | Kitchen Ranges
Viking 6 burner, gas stove top. When the back leftburner is turned on, it continually clicks. How can we fix this?
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module.
Gene
Aug 11, 2011 | Viking Kitchen Ranges
My burner on my stove top keeps clicking and it won't stop. I have somewhere to be in 30 minutes & I'm worried to leave it like this.
I'm guessing it's a gas stove. If that's the case , easiest thing is to just unplug the stove. possible problems are failed spark module or stuck ignition switch on one of the burner valves. send model # and brand and i may be able to narrow it down.
Dec 28, 2010 | Kitchen Ranges
I have a Whirlpool GS773LXSS gas range. You press bake, it clicks once and doesn't heat up at all. Press Broil, clicks twice and doesn't heat up.
Is the gas turned on to the stove? Is the pilot light lit?
Any special circumstances surrounding this incident? like this stove is new or old. Or you are new to gas stoves etc.
Apr 09, 2010 | Tecnik TKC195/3 Electric Single Oven
No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Nov 24, 2008 | Dacor Preference SGM466 Gas Cooktop
Operating manual
Hello
To get a manual for that stove go to this link:
http://www.technika.com.au/
I hope that help...Good luck
Eddie Rentas
Tupper Lake NY
Jul 18, 2008 | Tecnik Cooktops
Stove top burner Spectra XL4
rear left back burner clicks to ignite but doesnt
Feb 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top ignition
I have a Kitchenaid Model KGCT365x and need to replace the igniter switch on the front right burner. Can this be done through the knock hole or does the whol glass top have to be removed? If it has to be removed, what is the best procedure to do this?
Jan 01, 2008 | Bosch HES 252/ HES 256 Electric Kitchen...
Tecnik integrated dishwasher 795/2
make sure all filters are clean.make sure the wash arms are not cracked at the seam.if all that checks good you could have an obstruction to the pump.also check to see if you lose any water when running a cycle because the drain valve may be stuck open.the other possibility is that the impeller on the pump is worn or broke.
Aug 27, 2007 | Frigidaire 25 in. FDP750RC Free-standing...
Kitchen Ranges Logo
285 people viewed this question
Top Tecnik Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Tecnik Kitchen Range Expert? Answer questions, earn points and help others
