Question about Panasonic PT-51HX41 51" Rear Projection Television
Cannot get tv to switch to hd ,can only select sd on picture menu. could this be do to a bad signal ?
  • tformanik Nov 16, 2009
    Will call cable company. Thanks
  • 10,865 Answers
Hello. Definitely yes to your question. It could be the signal. Begin by calling your cable or satellite company and tell them what is going on. They have a vested interest in keeping you as a customer. They can also check the quality of your signal and tell you which channels you are purchasing in the HD format. Hopefully, your call to them will solve your problem, because it does not sound like the problem is within your HD TV. Thanks for choosing Fixya! Regards, Joe
Posted on Nov 16, 2009
ONLY HD picture does not fit on WS-55805
To be kind you are wasting your time, This is a 1st generation HD set not designed for the modern equipment you are using---You cannot turn a Model A Ford into a Roll Royce.
I has only one HD input designed for a set top HD box providing it a 1080 I signal.
Dec 04, 2012 | Mitsubishi WS-55805 55" Rear Projection...
I have a 27" RCA TruFlat TV. Recently the picture
Something has definitely gone wrong. When picture fails, generally the audio will still play; but since the set is shutting down completely after a short time - it is going to more involved.
Firstly, anything can be fixed. The questions to ask are: 1) At what point do you stop spending money to repair a device that is XX years old? 2) How much would a replacement / upgrade cost?
Given that your set is an older SD (standard definition) with an old analog NTSC legacy tuner, it may be worth while to make the move to a digital HDTV. The picture quality will "blow away" any SD version of the same image / program that your old TV displayed. Unlike several years ago, the HDTV has come way down in price, too. A 32 inch, wide screen HDTV price starts at just $235 as results shown by a search in Google. In order to view HD signals, you'll need either 1) a plain UHF/VHF antenna (and local broadcasters in range), 2) HD cable TV service or, 3) HD satellite service. Cable and satellite providers offer SD service and for slightly more, HD service. Most people are not happy watching SD signals on an HD display - so you'll probably want to change the level of service if you're not using an antenna. Old DVD players only send SD signals, you might consider upgrading to a Blu-Ray player. Blu-Ray players provide SD and HD signals - depending on whether you insert an SD DVD or an HD Blu-Ray disk. The Blu-Ray players, like the HDTVs, have also dropped in price significantly.
See if you can find a place that provides free estimates. If not able to locate, find someone that will apply the cost of diagnostics (ask what the diagnostic fee is) to the total repair charge, and decide to either fix or replace.
I hope this helps and good luck! Please take a moment to rate my reply - thank you.
Feb 25, 2011 | RCA TruFlat 27F520T 27" TV
Recently purchased a Sony Bravia KDL37EX403 1080p 100HZ flat screen tv. The picture seems to be poorly defined, almost pixelated around the edges of figures and letters - sport is almost unwatchable with...
Your old TV was most likely a SD (Standard Definition) TV. SD signals look better on SD TV sets than they do on HD TV sets. This is normal. If you will, imagine having a tiny wallet photo reprinted as an 8"x10" photo. The image would be grainy and not have the crispness of the original. This is the same principle. Your SD source is being blown up to fill an HD screen. Once you add HD to your programming, the old TV will be forgotten. I hope this was helpful.
Jun 12, 2010 | Televison & Video
Blurry picture
In the store they use an HD source and connection. Is your cable box HD? It will have component or hdmi connections if it is.You have use either one to get HD everything else will be SD(standard def).And you have to be on an HD channel.Digital cable refers to how the signal is delivered doesn't mean its HD. SD channels on digital still look bad..
Rustym62
http://www.the-tv-dude.typepad.com
Apr 28, 2009 | Televison & Video
Picture goes bad when playing Verizon Fios DVR or On Demand
I had issues when I set an SD override for the box, it would sometimes display as bad input when switching to HD content(as well as display all menus in SD even with HD mode in settings.) Turning that off in settings (also turned off "modes" which has no description) stopped it and gave me guide/menus in HD.
Apr 04, 2009 | Sharp Televison & Video
IN HDMI MODE MY PLASMA TURNS OFF WHEN I SWITCH FROM HD CHANNELS TO REGULAR CHANNELS
OK, Great ! I have the same box. What you do is press MENU on the remote. Scroll down with arrow keys and goto SETTINGS and press select. Scroll down to VIDEO SETTINGS and press enter. Press the right arrow key to go into VIDEO FORMAT. Make sure you have 1080i selected if you haven't had it selected already. Click continue and not your box will output only 1080i. Now, one more thing. While still in VIDEO SETTINGS, scroll down to SD OVERRIDE. Press the right arrow key and make sure you have this setting turned OFF. Press Menu few times to exit out. Now, your Motorola box will only output 1080i and will upconvert SD channels to 1080i. To test this, just simply switch from and HD channel to a SD channel and your TV should stated 1080i on both stations. You TV will not have to switch between resolutions. Hope this helps...
Mar 14, 2009 | Televison & Video
Certain HD settings won't work
no the set uses only two settings in the Y, Pb,Pr which it swithes back and forth. when a 480i,480p SD singal is detected it will switch to 480p, when an HD signal is detected it swiches to 1080i. when it swiches the picture scrambles for a second or two. to correct this in your cable box (if it's a motorola box) leave the tv on, press the power button on the box to shut down the box. next press the menu button on the box and the internal menu will show. use the cursor buttons on the box to select "480i overide" use the arrow to the right to select "streached" them hit menu to get out. hit the power button to turn the box back on.
Dec 16, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Use the "HD Selector" on the cable that plugs into your xbox360 and make sure it is pointing to "SD" and then turn on your xbox360. This should put the console in standard definition mode and allow you to see the picture on the screen. If this doe not work, check and make sure you are using the proper inputs on your tv and selecting those inputer accordingly.
Jul 05, 2007 | Microsoft Xbox 360 Console
Hd ready?
On any High Def TV, the reciever you need for this set, which does not have a HD receiver in it, is half the equation. Most HD channels have some HD content mixed with SD content on the same channel. SD content on HD signal from cable or satellite tends to be slightly blocky due to the native signal resolution and the resolution of HD (1080i/p or 720i/p).
Apr 30, 2007 | Akai PTH5498 54" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
21 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
