Question about Onkyo Audio Players & Recorders
Onkyo Integra won't play tapes drive won't
Onkyo Integra TA2090 cassette tape. .tape drive won't move...been idle along time..worked fine last time used....
fairlane
  • 50 Answers
SOURCE: No sound on cassette deck
Hi Does the deck have VU meters?...or a graphic display of some kind to indicate there is sound being picked up from the heads? If there are, and they are not moving or flashing, as the case may be, then you could have a wire off the head, or a problem in the preamp circuit, or if the deck is older, it could be as simple as a dirty play/record switch. I would need more info to help further. Good Luck!
Posted on May 02, 2007
  • 883 Answers
SOURCE: teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Posted on Jun 23, 2007
SOURCE: VHS has audio but no video
we cannot get the vcr portion to work only the dvd player4.gif works what are we doing wrong?
Have the same problem? Click Here
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video1.gif (yellow) RCA jack and S-VIDEO jack. If you are using the Component jacks, the DVD side will work but the VCR will not. This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Thank you for rating this solution.
Posted on Jan 01, 2008
SOURCE: Cassette Tape stuck
How does one take the cover off?
Posted on Feb 02, 2008
  • 579 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
Tape player will not play, but FF and REW work, as well as counter. model: Onkyo Integra TA2066
This unit uses a Sankyo type transport and after all these years and functions the feedback contacts may have become tarnished or the worm gear motor may have developed a dead spot. If you take the cover off the unit the first thing is to get a burnishing tool and work on the copper leaf contacts to see if that is it. This can be done with the power off. Then test the unit to see if that worm gear cam system will rotate. If not then the next course of action is to replace the cam motor as it has a dead spot on the commutator. You can confirm this condition by taking a small ***** driver and turning the worm gear quarter turn. Then try some play functions. If it works that is the problem. You will need to get a new motor and replace this- it is very involved and not an easy part to find and so a Technical person is better off doing this. If it does not move then it could be that the drive circuit is having trouble in either the supply or the drive transistors.
You will need to measure voltage in each direction it is suppose to turn. If it does not then on to the circuit board for the drive transistors.
Mar 30, 2016 | Audio Players & Recorders
When I place a tape in my Onkyo Integra TA2047 before I press any buttons it makes a humming noise. The reverse and FF work fine but when I push the Play button it starts rolling then slowly stops. I...
It can be a number of things. There are some models that are suppose to run the capstan when a tape is in and some unit that only run when the play is pushed. The proper operation and speed as well as cleaning can all be done by a Tape Deck Technician.
Aug 23, 2013 | Onkyo Audio Players & Recorders
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
I need replacement drive belts for an Onkyo
i bought some today from **** smith electronic store , i paid $7.97 for a pack of ten assorted sizes
May 18, 2009 | Audio Players & Recorders
Cassette tape spins fast
Hi Chris..
It's not worth repairing. I would find something else in good condition
Feb 01, 2009 | Onkyo TA-RW244 Single Cassette Deck
URGENT HELP cassette player problem, please reply
I HAD EXACTLY THE SAME PROBLEM ALL I DID WAS TAKE APART MOVED ALL WHEELS AND COGS IN SIDE AND JUST BLEW OUT ANY DUST CLIPPED BACK TOGETHER AND WORKED FINE PLAYS GREAT HENCE WHY IM LISTING IT ON EBAY.HOPE YOU HAVE SUCCESS
May 18, 2008 | Audio Players & Recorders
Recording problem onkya model ta2090
check electrolytic caps about the dolby chip. have seen caps (maybe 100uf) go dry and produce problems like this
Oct 31, 2007 | Onkyo TA RW544 Single Dual Cassette Deck
Cassette player on mx-d302t
Hi As you know cassette decks have been around along time, and as such they are fairly robust. The vast majority of the time, problems like you are describing are the result of a broken drive belt, or bad capstan motor. This is not true for all, but if you have favorite tapes you wish to play, you need the deck fixed, and if the problem is drive belt or motor, the repair normally should not be hugely expensive. Hope this helps, good luck!
Feb 23, 2007 | JVC TD-W118 Single Cassette Deck
91 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
