Question about Refrigerators
Defrost thermostat connections
I bought a new thermostat and I want to know if I can cut the two wires that run out the back of the refrigerator because the new part has 2 pin connectors on it for testing and a cap need help
  • 6 more comments
  • cmcan1 Jan 09, 2008
    It is an Amana S/S #sxd26vl and the part # is r0161088 in the install instructions it says these are test connections
    these wires are in the freezer compartment
  • cmcan1 Jan 10, 2008
    the evaporator was freezing up checked the timer and heater both work fine the thermo is freezing up and not working until it defrost
    do you know where i can get a schematic?
    what info do u need
    temp controls are manual
    thanks for the needed help
    that did it the wires are used during manufacturing to bypass the defrost limiter during testing and it states they can be cut at the wall when a new part is put on. thanks again
    President:
  • 1,314 Answers
Well what kind of fridge is it and you should not have to cut any wires at the back of the fridge as the defrost thermostat is in the freezer
Posted on Jan 09, 2008
  • 6 more comments
  • robert samples Jan 09, 2008
    just exactlly what is your promblem and how did you arrive at the defrost thermostat as the culprit thats a complicated model
  • robert samples Jan 10, 2008
    send me an e mail at b4829@yahoo.com
    im going to give a schmatic cant post here
    that model is electronic control right
    ok my bad you got the v series when you e mail me and i give you this url be sure to select v model cant do it on line classified info
    let me know if that helps or works lol
    thats what im here for dont forget to rate me im trying to get to gure whatever lol
    your welcome
I need step by step instructions on how to install defrost thermostat for model # GSS20IEPWW side by sideRefrigerator?
Empty the freezer. Unplug the fridge. Take all the shelves and drawer out of the freezer. Remove the lightbulb cover and bulb. Take out the screws that hold the panel on the back of the freezer wall. Slide the panel up slightly to clear the thermistor housing (a small 'bump' on the bottom left side) and remove the panel pulling from the left side forward. The defrost heater is on the bottom of the coils held on by two screws, and the thermostat is clipped on to the top coil and has pink and blue (sometimes orange) wires going to it. Don't worry if the wire colors on the new one are not the same. Unclip the thermostat and cut the wires, leaving yourself enough wire to strip them back and connect them with the new ones. Use crimp connectors or wire nuts (for wet applications) and then clip the thermostat back on. To replace the defrost heater, remove the two screws and disconnect the wires. The new defroster might have both wires on one side, rather than one on each side. That's okay, just move the wire on the left over to the right along side the other wire, and connect. Put everything back together, and plug back in.
Dec 31, 2010 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Kenmore 59662232200, freezer coils freeze up and will not drfrost automatically. replaced defrost timer, nothing changed. is there a heating elementing that should be replaced?
turn the timer knob until it clicks and the machine will be in defrost,remove the back wall inside the freezer,you'll see the defrost thermostat on top of the coil with two wires coming off of it,cut the two wires and reconnect the wires so you're bypassing the thermostat and the heater should come on,you'll hear a crackling noise when it comes on,before you cut the wires shut down the freezer control so no power is going to the wires,connect the wires and turn the control on,you can read out the thermostat with a meter but the t-stat has to be cold to read it out,the heaters in this machine hardly ever go bad but you can read it out with your meter.you have a new timer,all that's left is the heater,t-stat or a broken wire but i'd put my money on the t-stat.let me know what you find
Sep 25, 2010 | Kenmore Refrigerators
U-line 75R was not cold. Shorting the two wires at the thermostat, the motor runs and starts to get cold. Replaced the thermostat, but it didn't run at all. Please help. Thanks
There is a slight possibility that the unit's defrost timer just happen to be in defrost when you replaced the temperature control. Try advancing the defrost timer (or just let it sit for about 1/2 an hour and see if it comes back on). If you have more questions, let me know. Hope this helps!
Dec 11, 2009 | U-Line 75R Refrigerator
Defrost cycle not defrosting
Hi
Please check the defrost timer at the back of your refrigerator and also check the defrost thermostat. Defrost thermostat wiring(part #240) could be loose. You'll need to remove the back panel, held in place by 5 screws. Locate the defrost thermostat and disconnect it from the wire connection to another part. Due to the connection requirement, you may need to cut the wires from the original part and splice it with the connector with wires to the new part. After securing the spliced wires and covering in electrical tape, replace the panel and all the screws.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Jul 14, 2009 | GE Refrigerators
Hi, I have a westpoint WPS1602 fridge and the problem is defrost not working. I checked the thermostat, it suppose to be NC contact at low temperatures. but is showing open circuit always. The thermostat...
The thermostat should show open above 50 degrees to protect the refrigerator from over heating during defrost. If its not closing while frozen the thermostat needs to be replaced and that will get you going. The new thermostat come with crimp splicer connections and you only need to unplug the fridge and cut the two wires to it, then splice the new one in.
If that don't get you running again let me know and I will give some other things to check, Thanks, Sea Breeze
Apr 21, 2009 | Refrigerators
GE Refrigerator Defrost heaters are shorted to ground.
I feel like you have defrost thermostat wired wrong , One side of heater should have nothing hooked to it but one side of thermostat, whitch should shut it off when it goes open.Now some G.E.s have the evaperator fan hooked to the same wire,so it won't run when thermostat is open.If thats the case someone might have wired it wrong causing a back feed.check that out that could be your problem.Someone could have wired a hot lead to it not knowing it was supposed to go dead when limit control opened.hope this helps. God bless. Fxit
Feb 24, 2008 | Refrigerators
Fridge not getting cold
Hotfridge, you have an issue with automatic defrost... most likely located at the defrost terminator. Here are the steps to resolve the issue; First, go to your local appliance parts store and purchase a defrost thermostat. Part #WR50X55. It's a G.E. built part and will replace your bad one. UNPLUG YOU FRIDGE! You'll have to empty out your freezer compartment and remove the rear panel. Once this is done, you'll see the defrost thermostat physically mounted to the *evaporator. (*the aluminum coil assy. that's all iced up.) It looks like the one you just bought. Remove it from the evaporator and cut the wires right at the thermostat, then discard it. Strip the newly cut wires exposing 1/2" of wire. Strip the wires back on the new one the same as with your newly stripped wires. Wire color does not matter here, just connect one wire of your new part to one of the wires in the freezer, then do the same with the other one. Now mount it (use the clip provided) back to the evaporator where the old one was located. Repair complete. Except that you'll need to completely defrost (melt) all that ice out of there before it'll cool properly again. Grab a hair dryer for this job. Do this before you replace the rear panel, it'll go quicker that way.
Aug 09, 2007 | Haier HRE10WNAWW Refrigerator
Freezer works bottom part does not......
Yep, the ice buildup is restricting air flow to the fresh food compartment. This means you have a problem in your defrost circuit. First, go to your local appliance parts store and purchase a defrost thermostat. Part #WR50X55. It's a G.E. built part and will replace your bad one. UNPLUG YOU FRIDGE! You'll have to empty out your freezer compartment and remove the rear panel. Once this is done, you'll see the defrost thermostat physically mounted to the *evaporator. *(the aluminum coil assy. that's all iced up.) It looks like the one you just bought. Remove it from the evaporator and cut the wires right at the thermostat, then discard it. Strip the newly cut wires exposing 1/2" of wire. Do the same with your new one. Wire color does not matter, just connect one wire of your new part to one of the wires in the freezer, then do the same with the other one. Now mount it (use the clip provided) back to the evaporator where the old one was located. Repair complete. Except that you'll need to completely defrost (melt) all that ice out of there before it'll cool properly again. Grab a hair dryer for this job. Do this before you replace the rear panel, it'll go quicker that way.
Aug 01, 2007 | Avanti FF1102SS Top Freezer Refrigerator
Refrigerators Logo
257 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
