Question about Frigidaire Affinity ATF7000E Front Load Washer
Error code e71 on frigidare atf7000ego - Frigidaire Affinity ATF7000E Front Load Washer
2 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: ERROR CODE E20 FIDGFIDAIRE (ATF7000EGO) FRONT LOAD WASHER
    You are experiencing a water pump issue. . Check the drain hose for restrictions. Restriction, correct problem. No restriction, go to step (2). 2. Start the washer and check for 120VAC at the drain pump. Zero, replace the Main Control Board. 120VAC, remove the pump and check it for blockage. If blocked, remove the restriction, if not, replace the pump.
    Posted on Aug 27, 2012
    ERROR CODE E71
    Error code E71 relates to the water temperature sensor and if the connections are okay this may need replacing.
    Dec 02, 2015 | Washing Machines
    I have Frigidaire Affinity ATF7000EGO washer. i just replaced the door striker but now everytime it goes to start cycle starts buzzing and reads DR....
    Double check that the mechanism is fitted correctly and all wires are attached as off the top of my head that is the error code for the door not sealed properly. Hope this helps.
    Nov 17, 2013 | Washing Machines
    Toshiba AW-SD150S error E71 what does it mean?
    my washer Toshiba AW-SD150S washer can not funtion .it will come out error code E71.some body can tell me what is the problem
    Jan 26, 2013 | Cell Phones
    Aug 23, 2012 | Frigidaire ATF6000ES Front Load Washer
    New Calendar or Memo entry shows System Error
    dear u can restore ur phone by usiging ur security code. ur default code is 12345. thanks
    Jul 27, 2009 | Nokia E71 Smartphone
    My xbox got one ring with error code E79 or E71
    Well, E79 and E71 are different things.
    The E79 is an error code representing a Hard Drive error. It could be the HDD itself or its a connection problem with the hard drive. Try playing your 360 without it and see what happens.
    E71: possibly a dashboard update error, there is no solution at present the console must be sent back to MS for repair. Try resetting your console, or Power Off, remove the HDD if you have it. Reconnect the HDD.
    Jul 15, 2009 | Microsoft Xbox 360 Console
    Whenever i try to change lock code to nokia E71,it says code error
    yes,from factory it's set to 12345. you need to type it first and then your new code. must be 5 digits.
    May 12, 2009 | Nokia E71 Smartphone
    CLC 1110 E71?0007, E071?0002, E072 error codes.
    On my CLC 1150 copier machine, I have an error code E071 – 0002.
    Sir plz send soluation this error
    Dec 12, 2008 | Canon CLC 1110 Copier
    Frigidaire Affinity ATF7000E Front Load Washer Logo
    145 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Jason Harris
    Jason Harris
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
