Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
I bought this dozer blade uses and cant figure out how to attach it to my tractor. Is there a mounting bracket that bolts onto the tractor? Are there any pictures of this or an installation manual with a parts list?
    Scholar:
  • 81 Answers
You can go to sears.com and lookup the tractor part number and snow blade part number and they will show you all the brackets and attachments needed. Also the site will show all tractors that the snowblade will fit. Hope This Helps Don
Posted on Dec 02, 2009
Pulley is hitting mower deck when raised to the stop position all i did was change the blades all brackets are installed in the same holes,what gives?
Hi, re check your hanging bracket positions if it was ok before changing blades as been incorrect will cause the deck to travel to far when disengaging the blades, regards Phil
May 10, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
Removed mower deck with no problems. Cannot re-attach. Do you have a step by step instruction for this process?
1. Raise attatchment lift lever to its highest position
2. Slide the mower deck under the tractor with deflector shield (grass Chute) to right side of tractor
3. Lower lift lever to its lowest position
4.. Connect the front links to the mower deck and secure with the retainer springs.
5. Connect thye suspension arms to the rear deck brackets and secure with their retainer springs.
6. Connect the anti-sway bar to the chassis bracket and secure with the retainer spring.
7. Push the clutch cable housing guide into the bracket, and slide the collar onto the guide and
secure it with the large retainer spring.
8. Place the flat washer and clutch spring on the idler pulley bolt and secure them with the small
retainer spring.
9. Re-install the blade belt onto the engine pulley it goes on.
Apr 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have john deer sabre 18 horse i have a snow blade but cant get on right
My name is Dane and I'll try to help you with your problem. I have given you the basic instructions here for mounting most john deere snow blades.
Here is a link to the parts diagram for the blade too.
http://www.searspartsdirect.com/partsdirect/part-model/Sabre-john-deere-Parts/Riding-mower-tractor-Parts/Model-15538G/1828/1509200/10060752/00034
You need to remove the mower deck from the machine, and you may have to remove the front bumper as well.
First, install the mounting brackets on the tractor. Align the holes in each mounting bracket with the holes in the tractor frame. Install using the kit that comes with the mounting bracket. Don't tighten this yet.
Next you should install the pivot support. Insert the pins on the right and left hitch plates into the notches on the mounting brackets. Install the pins and tighten the screws on those mounting brackets now.
Next you should Install the blade. Align the holes in the pivot support with the second holes from the end of the push channel assembly. Insert the channel pin and washer and secure with the spring locking pin.
Install the lift handle. Slide the lift handle rod into the end hole in the push channel assembly. Insert the lift link pin in the pivot support bracket into the lift handle rod. Add the washers and locking pin.
Now, Iistall the blade pivot rod. Either end of the blade pivot rod goes through the blade pivot shaft. The other end goes through the lift handle tube. Secure both ends with locking pins.
Lubricate the lift handle rods and pivot points.
Install the rear tire chains and wheel weights.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thanks! Dane
Dec 03, 2010 | John Deere Garden
I am trying to replace the starter in my 86 nissan stanza but cant see it
NISSAN STANZA WAGON - Manual Transmission
Q. Where is the starter on a 1986 nissan stanza station wagon and how do you get to it ?
Due to limited access to the starter, it is recommended that the transaxle be removed when servicing the starter.
REMOVAL:
1. Cold vehicle.
Remove 2 mounting bracket bolts, 10 & 12 mm (Figure 1).
Remove top starter motor bolt 14 mm with universal & long extensions.
Raise vehicle on hoist.
Remove front splash pans 10 mm.
Automatic transmission: Drain 2 qts out.
Remove rt-ft wheel 21 mm., & tie rod (Figure 3), axle cap, cotter pin, adj-nut & rubber washer.
Remove ball joint nuts 17 mm., left lower control arm 19mm. & swaybar bracket 14 mm. (Fig 2).
Remove axle nut 36mm (Figure 4), the front tube, catalytic converter heat insulators 10mm, ctr ex-tube 17 mm., and front tube from exhaust system (Figure 5).
Remove long bolt from ft engine mount (next to radiator), 17mm socket (Figure 6, Item A).
Remove tension rod mount 14 mm. Has adj-bracket with rubber insulators (Fig 6, Items B, C).
Remove right side drive shaft bolts that hold shaft to bracket mounted on engine (Fig7) 12mm.
Remove rt-driveshaft.
CAUTION: Transaxle side seals are cut by spline teeth.
Install hoist type transmission jack and wooden block under the transmission/engine. Be certain the transmission is safely balanced on the hoist.
Remove 5 engine crossmember mounts (3 bolts, 2 nuts) 14mm.
Remove nut that attaches crossmember to engine mount.
Loosen stabilizer bar mounts to allow adequate clearance for crossmember to be removed.
Remove following brackets to allow starter assembly to pass through bottom:
tubular support bracket - engine to transaxle
angled support bracket - driveshaft bracket to engine mount
manifold collector stay - (bottom bolts)
Loosen top bolts, remove bracket above driveshaft-holding bracket 14mm.
NOTE: This bracket is slotted to allow it to slide out without completely removing the bolts.
Remove bottom starter motor mounting bolt.
Separate starter assembly from bellhousing, DC all cables/connectors, remove starter motor.
When installing starter, connect cable, install/torque starter bolts.
Nov 03, 2010 | 1986 Nissan Stanza
I recently tore the plastic shroud off the mower deck of my Craftsmen 18.5 horse lawn tractor (2004) by hitting my fence. This is the shroud that covers the blades. I went to the Sears store and looked...
Unless you find someone that has experience with this mower, and that's not working so far, you're going to have to figure the attachment points out yourself. I would suggest that you run the machine by a shop, or mechanically inclined neighbor, and have them look and at, and explain the dilemma. They will probably know, or can figure it out for you, and maybe even get it attached for a few bucks, or free. Since time is of the essence, I feel these are your best shots, since it's not obvious exactly where those straps go. You can always inquire locally, and for free, through Craigslist, whether anyone in your vicinity has your model so that you can see how it's attached. Wish I could be more specific, but this is all I can think of to suggest, and hope it helps.
Jun 15, 2010 | Garden
Got a 42" snow blade and no paperwork with it.
Ok that snow blade attachment was Made for Sears/Craftsman by AGRI- FAB. Go to thier website. Email them that you bought model number xxxxxxx and there were no instructions in the box. They will either tell you how to down load the instructions or send them too you. I have had the best luck with AGRI-FAB they like happy customers.
Oct 18, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
We are trying to figure out how to assemble our 42" sears craftsman snow plow.
Go to sears.com and click on the PartsDirect link at the top. Enter the model number of your blade and you will see a parts diagram of it.
Dec 21, 2008 | Craftsman 16" High Garden Tractor Snow and...
I have my dozer blade on the tractor but it won't lift up or down and i can't figure it out
how are the Hyd line attached?
must get right hoses in inlet and outlet.
Is tractor hydrostatic or Geared?
Nov 28, 2008 | Craftsman 16" High Garden Tractor Snow and...
Mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Sep 29, 2008 | Garden
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
418 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
