Question about Dryers
How do i take off the back panel of a zanussi condenser dryer the wiring in the top left is stopping me
    Scholar:
  • 62 Answers
The wiring shouil have connector plugs on them. make a note which plug fits into whick socket. You havent given module number but I am guessing you can either see the motor on the top left or a heater box.
Once these connectors are removed you should be able to remove the back cover.
regards
AArdvark repairs
Posted on Nov 16, 2009
How to repair a zanussi condenser tumble dryer belt
Access from the rear panel to drive belt:
- Remove the worktop
- Remove the side panels
- Remove the rear panel cover
- Remove the motor unit
Dado
Oct 03, 2014 | Zanussi TC7102W Electric Dryer
How do I replace the thermostat switch on a Zanussi ZCE 7701CH? I have removed the screws for the side panels at the rear but cannot access the screws for the side panels at the front. The Product No...
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Jun 18, 2011 | Zanussi ZCE7551X Electric Kitchen Range
Zanussi 7102 won't start. Power is ok. Condenser tank full light remains partially on even when tank is removed. When startbutton is pressed condenser full light illuminates fully. Water pours out pipe...
Pat, Have you found a solution to this yet? I have got exactly the same fault today ! Having taken the top & left side of the dryer off, I found what looks like a broken drive belt - not the main drum drivebelt which is fine, but a shorter one (about 18cm diameter loop) with no obvious place for it to have come from. Any clues would be appreciated. Dave (drdave@fsmail.net)
Dec 31, 2010 | Zanussi TC7102W Electric Dryer
Full water indicator lit continuously even though
Problem was a stuck float in the small water reservoir to the rear left of the unit.. Remove top and left hand side panel. Small reservoir can be seen at the bottom left. Remove small screw and slide off the cable assembly above. You should then see into the reservoir and the float. Clean float and reservoir and reassemble.
Feb 08, 2010 | Zanussi TC7114W Electric Dryer
Zanussi condenser dryer stopped working - smell of burning?
sounds like you fried a heat element wire could have a lint build up problem ck and clean ventilation system if cabinet has alot of lint inside chances are that is the smell if you do not find burned wiring if alot of lint is present could have fried the thermal fuse and or limit switch
Jan 28, 2010 | Dryers
Bosch dryer warning sounder for container full will not stop
Hi
You need to remove the left side panel, this is the side where the drain container is, once removed you will see the drain pump with two pipes coming from it, remove the pipes and top cover, disconnect the wiring, remove the pump unit with the clip, clean the float unit and pump, also remove the congealed mess in the water trouth as this is what holds the float up and makes the machine think the drain container is full.
I bet you will find this will cure the problems you are having, it did with mine.
Sep 07, 2009 | Bosch Dryers
Zanussi TCE 7276 W Condensing Dryer
hi i have a problem with the zanussi 7276w model all lights are on ready to start but the tumble dryer will not start
Sep 21, 2008 | Zanussi TC7114W Electric Dryer
Zanussi ZDC67550 Dryer, door swing change?
Hi
just reversed the doors in 15-20 mins. It worked for me. You do need to be a competent DIYer to do this.
If in doubt, do now't. Get in an engineer
Disconnect from mains (obviously)
Remove top using 7mm nut driver/spanner
Remove 2 cross-head screws holding the door - Door will come away from dryer.
Remove 2 cross-head screws holding the white top and bottom blanking plates
pull out the switch blanking plate
Locate the PINK wires connecting the switch/latch mechanism inside the dryer at the top. This will be taped to a blue wire.
Unscrew the 2 smaller cross-head screws holding the latch/switch assembly whilst holding the pink wire to stop the mechanism dropping inside the dryer.
Pull up the latch mechanism and unravel the black tape holding it to the blue wire.
Drop the latch assembly down the lefthand side of the dryer and refit using the 2 small cross-head screws.
Retape to the blue wier and feed the PINK wires through the plastic retainers.
Fit the white blanking plates to the RIGHT handside of the door opening.
Swap the hinges and the switch latch on the door (don't lose the spring !!!, refitting the hinge blanking plates(ease these out with a small flathead screwdriver covered witha bit of insulating tape to avoid damage.)
Fit the door using the 2 cross-head screws you have left
Refit the top.
Connect to the mains and switch on to the sound of £80 you have just saved yourself !!
Electricity kills Be careful
Oct 03, 2007 | Whirlpool GEW9250P Electric Dryer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
