Question about Canon i455 InkJet Photo Printer
Canon i455 printer - cartridge carriage broken?
When I turn on my printer, I hear a rat-a-tat noise and the light blinks from green to orange and back again. When I open the door to where the cartridges are, the cartridges just stay put on the side instead of swinging to the middle. I assume the noise is related to this.
Can this be fixed???
  • 233 Answers
Carriage is jammed, turn off and see if you can manually move it
look for paper jam or other objects (paperclip,staple and so on). remove cartridges and inspect.
hope this helps
thanks for rating
Posted on Jan 09, 2008
Canon bjc 3010 waste ink error
just clean your cartridge..align it properly when you it back..surely it put properly.
Feb 08, 2014 | Canon BJC 3000 InkJet Printer
Flashing green orange lights
The Canon service info is:
B200/P10 - Orange and green light blinking 10 times Description: A service error has occurred. Resolution: 1. Turn off the printer. 2. Disconnect the power cable. 3. Open the printer cover. 4. Check for any orange protective tape or white polystyrene and remove if necessary. 5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary. 6. Close the cover. 7. Reconnect and turn on. If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
The error code is usually given for a foreign object present in the print head carriage path, so check at both ends for a crumpled up wedge of paper. If nothing is found, it is most likely that your print head has an over-heating problem and is dying
Dec 10, 2017 | Canon PIXMA iP4600 Color InkJet Photo...
Its stop printing and the LED power light green and orange at the center blink, like there is a paper jam.
Feb 11, 2010 | HP DeskJet 1280 InkJet Printer
Flashing lights and no printing
If the two lights are blinking persistently and the carriage is moving freely when the cover is opened then the logic board has problem and should be replaced. However, if there is some restriction of carriage movement or cracking noise, the optical cable should be replaced. Good luck
Apr 29, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon S520 printer won't print
there is a encoder strip in the printer to which the cartridge head carriage reads .if this encoder strip is dusty or loose the carriage cannot read so it bangs from left to right.and due to this printer cannot get set to its position.and the orange error light blinks.that transperant long strip with blacl vertical lines on it has to be checked.
Jan 29, 2009 | Canon S520 InkJet Photo Printer
Orange LED blinks 5 times then a 2 second green
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10239
If you type in 'flashing power light' in the problem box, for 5 you get print head failure, often it means the connectors between cartridge and print carriage are dirty, can be cleaned with a pencil eraser and a soft cloth. there is a sequence of checks and repairs to follow on the canon service page
Sep 02, 2008 | Canon PIXMA iP4000R InkJet Printer
Canon i455
Seems like your waste ink absorber is full. Try this procedure. It works for a lot of Canon printers.
1. Press and hold the POWER button
2. Turn off the printer by disconnecting the printer power cable,
3. turn on the printer, still holding the POWER button
The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
7. Reconnect the printer cable.
8. And it should be reset.
Jul 18, 2008 | Canon i455 InkJet Photo Printer
Canon i560 Ink jet Error Code 5C00
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
May 05, 2008 | Canon BubbleJet i550 InkJet Printer
Orange cartridge light error keeps on blinking!
clean the carriage home
check the data cable for the carriage home
check the media sensor on the left of the plotter media bar
Mar 12, 2008 | HP DesignJet 450c InkJet Printer
Canon i455 InkJet Photo Printer Logo
162 people viewed this question
old marine
old marine
