Question about Kenmore 62602 Electric Dryer
Our dryer will not stay running, it stops about every 2 minutes and needs to be restarted. But it starts again with a single push of the button, only to stop again in a few minute.
    Scholar:
  • 86 Answers
That is interesting - I've never come across that (and I've seen a lot). I would hire someone.
Posted on Nov 17, 2009
Our dryer will not stay on
Posted on Nov 16, 2009
When pushing the start button the dryer will come on for about 10 minutes and then stop. Then sometimes it doesnt come on at all
If it starts right back up after stopping there is an electrical problem maybe at the motor start switch. If you have to wait for an hour before it will start again then the problem might be that the motor needs to be cleaned of a lint build up.
Oct 23, 2012 | Roper RES7646KQ Electric Dryer
I have a kenmore he3 dryer that won't stay on. When I push the start button, the motor will turn the drum about a quarter of an inch then stop. I then need to push the pause/cancel button once and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 16, 2011 | Dryers
Dryer stops running shortly into cycle. When button is pushed to restart, dryer groans. Holding button may get the unit going again - but it makes noise running and stops again soon. Bad motor? Bad...
Sounds like start winding switch. I would replace whole motor assembly. Try on ebay for a used one that looks newer. Used motors will save you some serious money.
Jun 21, 2010 | Speed Queen AES28AWF Electric Dryer
Runs for 2 mins. then stops, push reset button & will run for 2 minutes & stops again
How long have you had the dryer? It sounds like it is overheating, and the most likely cause is accumulated lint. You can check this by removing the round plastic covers on either side panel. Just rotate them and they will pop out. Clean out any lint you see in the air channels and replace the covers.
Also check your ducting - it may be partially or fully blocked by something. You could test this by disconnecting the ducting, then running the dryer to see if it still shuts off. (Prepare for some loose lint flying out in this event.)
Jun 01, 2009 | Asko T701 Electric Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
62802 stops running after a few minutes
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Oct 15, 2007 | Kenmore 62602 Electric Dryer
Whirlpool dryer (electric)
did the button click when you pressed it when it worked fine, if it doesn't click now then you need a new button switch, which should be fairly cheap and fairly easy to replace yourself with care if the button should be pressed to start without normally clicking and needs to be pressed to restart each time you open the door then the start relay could be faulty, sound complicated but not the same fault hope i have been of some help, if so please rate me
Oct 04, 2007 | Whirlpool LEQ9858P Electric Dryer
Kenmore dyer
sounds like the timer, unless it has a Evenheat contol board and a seperate motor relay, in which case its most likely the relay, or could be the computer
Sep 29, 2007 | Kenmore 64892 Electric Dryer
Dryer runs for 5 minutes then stops
look in the vent line for a small disk shaped overload with two wires coming out of it. it may be bad. also check for a lint build-up in the exhaust line out of the blower. check the damper outlet going out of the house for a build-up of lint.
Aug 21, 2007 | Roper REX3614KW Electric Dryer
Kenmore 62602 Electric Dryer Logo
122 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
