FAX machine prints a dark band down one side of the paper
I use my (quite old) thermal fax machine as a copier.
It is putting a dark wide band down one side fo the paper. I have cleaned the glass where the scanning takes place, and the white strip above it, but that did not help.
When I use it to send a fax, the recipient complains about the dark line too.
    President:
  • 3,085 Answers
Your thermal head is defective. No replacement parts available.
Posted on Nov 17, 2009
Testimonial: "Thanks for the definitive expertise."
No problem, but don't know if the print goes face side up por down into the printer when faxing
Where you put the paper must be a little icon like a page with lines, if you see this put the paper face up. I am surprise you did not check with a fax recipient to see if they got it (Blank paper or the fax)
Mar 18, 2011 | Office Equipment & Supplies
Incoming faxes have dark bands accross the page. The bands are 1/4" wide and spaced about 1 1/2 " apart.
Sounds like it needs a new drum. You'll have to replace the toner at the same time.
Oct 14, 2010 | OKIFAX 5650 Plain Paper LED Fax
BLANK PAPER
If you receive a fax with blank pages , nine times out of 10 the answer is that the sender fed one or more of the sheets into the fax machine upside down or backward. You can confirm that this is what happened by noting whether the header (lines of sender information) is present.
You could also be experiencing a technical or mechanical problem, such as a need to fix or change parts. You can test whether your machine can print at all by using its “copy” function, or print an activity report. If all is well on your end, the problem must be with the sender’s machine.
If, by any chance, you’re using an old thermal fax machine, check to see if the roll of paper has been put in backward, because if that’s the case the heads won’t print on the side that isn’t heat-sensitive.
Thanks for using Fixya.
Apr 16, 2009 | Office Equipment & Supplies
2" BOTH SIDES WHEN SENDING BLACK
This is because your **** Glass is Dirty Clean your **** Glass and it will be ok.
remove ALL WHITE OUT
Mar 07, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Dark Horizontal Lines on Faxes
on the drum unit that you put your toner inn, There is a blue or green slide lever move the slide back and fourth 10-15 times. If you have some van air blow that area out ( F.Y.I. if you do this some toner will fly out ) if this does not take care of it the drum unit my be bad,
do a 1/2 print test. copier something with a lot of print. open front cover when the paper is 1/2 way through the machine remove drum. Look art the paper and the green drum if the marks are on the paper & drum then the drum is bad. If not the fuser asm is bad, the part that gits hot when melting the toner on the paper,
Jan 29, 2009 | Brother IntelliFax-2820 Laser Fax
Panasonic kx-fp155 not printing
problem is not clear.u change fax roll when it was finished.if fax was printing before ending roll .i think u have installed roll with wrong side .thermal roll only prints with one side which is coated .just see inside machine there will bi a paper for installing roll direction.if not just check thermal head .clean it check its supply.or just replace.it mian jee
Jan 13, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
Panasonic KX-FPG376 Plain... Problem:
Thermal paper roll upside down. You can only print on 1 side of thermal paper. also could be the thermal head in which case not worth repairing. Lawrence
Mar 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
for printing of this machine ttr roll is use you check with another quality of that like canofax roll and cheak out for machine printing.
Mar 11, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
96 people viewed this question
jasbo
jasbo
