Posted on Nov 16, 2009
Poor black print quality black prints greenish grey
Sajid Najmi
Level 1:
  • Contributor 31 Answers
  • Posted on Nov 18, 2009
Sajid Najmi
Contributor
Level 1:
Answers
31
Questions
Helped
12766
Points
69
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
  3. Verify that only KODAK branded ink cartridges are installed.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door, then make the same print.
If issue still continues:
  1. Verify that inkjet paper is loaded in the paper tray.
  2. Press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes green. The On/Off light continues to flash during the cleaning procedure.
  3. When the On/Off light glows a steady green, press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes, then wait for the demo sheet to print.
the printhead for your printer is in need of replacement. Contact Kodak
Best of Luck
I'm not quite satisfied with color and black tone. What settings would you recommend.
You do not say what exact model of printer you are using so any answer will be generic rather than specific.
Poor colour and black tone can be as a result of various factors:
1. Poor paper quality that you are printing on.
2. Poor ink or toner quality being used.
3. Use of Ink / Toner saving modes or software.
4. Worn or damaged printer components such as the fuser roll on a laser printer and other similar consumables with a limited page use life.
5. Poor quality content being printed, i.e. low quality images being printed at too high a print resolution.
Have est7 printer .... won't print without 'good' color cartridge. can't reset to go 'black only' . is this a design issue or just poor documentation.? I bought Kodak because of its...
first up
in a printer to get good black grey contrast etc, color is used
next when you get set to print, press settings and then click on black
make default and ok
Kodak reputation is not universal because it is average quality
Printing black on paper
Some of these machines will allow you to printe a grey scale test copy.
This will readjust the fax machine back to a nominal mode.
Not knowing how old or how long the machine has been serviced, background can be caused by dirty optics somewhere in the machine.
A remanufactured drum unit can cause this type of problem, (defective unit)
Competitive toner in the toner unit can cause poor copy quality.
Reinstall the old cartrige and see if the problem changes.
Not knowing if the machine has a seperate drum unit and developer housing, it would be hard to answer anything else.
Print clarity
Check the print result by using Ink Management -> Testpage. After printing the test page, you'll get questions about the print quality, answer them and perform the cleaning after the questions. Repeat this process up to five times, which should solve the problem.
1helpful
Printer has set for a while. The print quality is very poor. Black is grey, there are streaks across the page.
Take the cartridge out and shack it side to side a few times to move the toner around and reinstall it.
1helpful
Prints in black are poor quality
fist of all reunisall your printer driver ....
if problem dose not fix .
it means black colour laser section have problem so you can clean lens of laser if posible and replace laser secaner.
thanks
2answers
Greenish tint to black type
This is a dot matrix printer. The way they work is there is a print head that has a heap of little needles with flat tops on them, and they push out at high speed against the ink ribbon, and the ink ribbon is pushed against the paper to make a dot. Then the pin is retracted, spring loaded.
Pretty amazing that it can work that fast, eh!
So the only thing that can influence the ink colour on your paper is the ribbon.
Are you using original Lexmark ribbons? If so, my recommendation would be to take a sample print to where you got the printer from and get them to demonstrate the print quality of one of these printers, then compare it with yours.
Dot Matrix printers will not produce print as black or as high a quality as a laser printer, for example.
Perhaps the ink ribbons you are using have a less than top quality ink in them, and there is a bit of "bleeding" going on - it can only be the ribbon.
Another thing you can experiment with to get the best print quality is the print head gap - there will (should) be an adjustment, and getting that right will make a difference to print quality.
Hope this helps you.
Poor quality black output
There is a defect in the Imaging Unit of these printers....if you replace the imaging unit, the problem of the faded black prints go away. If you have less than 7000 prints, you can call Samsung for a warrantied replacement. The Imaging Unit is supposed to last at least 20,000 prints.
2answers
Phaser 6250 black toner is super light
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Click on Knowledge base from this site , then in the search box enter poor black quality. Look under black is faded or missing
5helpful
Poor Print Quality on Epson Aculaser C1100N
Sounds like the black dev unit is worn out. Easy enough to change yourself if it is out of warranty. If it is in warranty get Epson to do it for you.
k24674
ADMIN Andrew
ADMIN Andrew
