Question about Hotpoint HSS25GFP Side by Side Refrigerator
Clicking sound in back of frig, isnt cooling
Clicking sound in back can see the fan in the freezer turning. After a long time of clicking sometimes it will kick on. I have lost a lot of food waiting for it too start up, it isnt cooling like its suppose too
  • 555 Answers
The clicking is related to a relay next to the compressor. Something is not allowing the compressor to run, perhaps an overload, broken motor, relay failure, etc.
It's a good idea to get ice to save the food, don't wait more than 4 hours to see if the fridge will cool by itself. Avoid food poisoning.
As the symptoms are too broad to determine exactly what is wrong, the first thing to do is to replace the relay. If the problem continues, you may need to contact a technician.
Posted on Nov 16, 2009
Why is refrigerator not cooling
May be out of gas, or low on gas. Can you hear the unit running when you power it up?
May want to check on the overload unit to see if it is ok
Bruno
Sep 06, 2014 | Whirlpool Refrigerators
Freezer doesn't cool to 0 even though it's set at -5
There is a fan that blows air past the coils in the freezer. Either the fan is not working or the coils are blocked with ice. Sometime ice stops the fan from turning. listen for the fan spinning by turning the thermostat down. Defrost the coils and fan and see if the frig returns to normal. Sometimes the drain tube is clogged causing ice buildup.
Feb 13, 2014 | Whirlpool GB2SHKXL Bottom Freezer...
Frigidaire FRT21INLH top frezer refrige its not cooling i hear clicking in the back,friend who use to work on them said sounds like start relay but dont knw if i trust him if that is it were is it located...
HI, sounds to me like ice build up in freezer and the clicking sound is fan blade hitting ice.If you can remove back panel inside freezer and if you see ice, you will need to clear ice which is also blocking vent that goes to frig to cool it.then i would recommend wrapping a heavy guage copper wire around heating element and putting other end down drain tube to prevent the ice build up.
Mar 05, 2011 | Frigidaire FRT21P5A Top Freezer...
My Frigidaire refrigerator is at 60 degrees Fahrenheit and will not cool down
There are a few possibilities. First, Is the freezer portion working okay? If yes, then the problem is blocked air flow from the freezer to the frig. If no, then the cooling fan could be bad or the thermostat could be bad. First check for temperature in Freezer section, should be about 4-8 degrees no more. If it is cold, then locate the cooling fan behind the back of the frig and see if it is moving or listen for movement. If it is moving then rearrange the food in your freezer compartment.and frig compartment away from the vents. If it is not moving, then the thermocouple could be bad. compressor problems and freon leaks are not that common unless the frig has been moved alot. The cooling fan or thermocouple or overstuffed freezer compartment are the usual suspects in 90 % of cooling problems. cooling fans and thermocouples can be cleaned by using canned compressed air to remove dust which will sometimes cause a failure. The parts are inexpensive but labor is about $80. Start with the freezer because all of the cooling for the whole unit starts in the freezer.
Dec 18, 2010 | Frigidaire Refrigerators
The lower refrigerator section is not cold anymore
check to see if the fan motor in the freezer is running. all the cooling happens in the freezer and the fan is what circulates the cold air down to the refrigerator.. if the fan isnt running ,it could be a bad connection or a bad fan motor..on some models the doors need to be closed before the fan comes on so just push on the door switch to check .if the fan is running then a defrost problem may be the problem.. you mentioned you defrosted the unit. if the auto defrost isnt working, you would notice frost on the back of the freezer. there would be a lot more frost behind that panel that could block the airflow down to the frig. you would have to remove rear panel of freezer to clear all the frost and restore proper airflow..remember to unplug the frig before doing any work..
Mar 25, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
The Freezer and Refrigerator has stopped working completely
first check to see if the compressor and fan on the lower back of frig is working,if it is then check the freezer to see if the freezer fan is working,if it is then find the defrost timer(most of the time behind the front grill or inside frig. or on lower back)turn it til it clicks,wait 30 minutes and see if it comes out of defrost(you k=will know this if the freezer fan comes back on,let me know what you find-mike
Apr 16, 2009 | Refrigerators
Frig. and Freezer not cooling. Clicking sounds heard every 2 mins
sure sounds as if it is def a compressor overheating, now that the compressoe will be cooled it should work , but your right damage may be already done, the good news if any is that you should be covered under 5yr manufactures warr for compressor
Dec 22, 2008 | Maytag MTF2155GRW Top Freezer Refrigerator
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Frig section not cooling and at time appears to stop but freezer is ok
There is one compressor, condenser and evaporator in all refrigerators. The part that makes the cold inside the unit is the evaporator. It's in the freezer, behind a barrier on the back wall. It's a "coil" with many small fins. There is a fan that blows air over the evaporator which makes the air cold. This air comes from the freezer and stays in the freezer. The cold food section (the refrigerator) has a control that opens a hole for air to pass from the freezer to the fridge. This being said...you can rule out the "temperature control" for the fridge.
The sound you hear could be the compressor relay, the evaporator fan or maybe something else. It could be bad, it could be not too bad. (Like a fan blade a bit unbalanced with dust)
OK,,, back to the evaporator. There is a little heater next to the coil that turns on every 8 hours or so to defrost the coil. That's called the "defrost cycle". Makes sense, no? If the defrost timer (common problem) or defrost control board (common problem) go bad, your evaporator coil freezes up, and that's not good for anything in your refrigerator. But it can often keep the freezer section cold. You can easily disassemble the evaporator cover in the back of the freezer and take a look. If it looks like a block of ice, you probably have a defrost issue. An even, thin coat of frost is OK, but lots of ice is a no no.
Jun 26, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
104 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
