Question about Honeywell International Honeywell R8222B1067 General Purpose Switching Relay
HOW TO WIRE A HONEYWELL R8222 B 1067 RELAY TO MY AIRHANDLER BECUASE I AM HAVING A FEEDBACK
Airhandler- the themostat is on auto/I understand cool,heat.emerg heat,The (G) terminal-then why heat mode or,emer heat fan blows?Only when i switch to cool mode the handler still want start up blowing...
the fan fill come on with the sequencer (stack switch you call it) it will also come on with the fan relay. on some goodmans the fan relay is the black box on the circuit board. use a jumper to jump red to green, this should bring the fan on sounds like you could have a broken green wire, try using a different wire instead of green
Sep 12, 2013 | Goodman Heating & Cooling
I have an existing honeywell thermostat - 4 wire hook up. I added a honeywell humidistat. I hooked it up for series operation meaning when we leave the house in south Florida for the summer, the humidstat...
That 's a really good idea. My question would be is that a two wire humidistat? If it is. you would have to parallel the wires. One wire on the "R" on the thermostat and the other would go on "Y" and jumper to "G". Really interesting , I would like to know if it works. I live in Okla. and we have real high humidity summers but probably not like Florida. Hope this helps you.
May 14, 2011 | Honeywell Heating & Cooling
Heat function does not work
If this was just put int, it's under warranity, Call the installing dealer to have them come out and take a look at it. We don't advise you to do anything with it since it may void the warranty. Most of the time it is a wiring problem. How were you able to vacuum out the lines before you released the charge? the thermostat sub base has a place to connect a wire usually white to energize the heat strips when you push the stat way hotter than the house temp. that is why the strips come on in normal heat. it also has a terminal that is only energized in emergency heat and it also should have a wire connected to it so that terminal can supply power to the strips when the stat is switched into emerg heat . you can identify the terminal from the wiring diagram and if need be jumper w2 wire over to the aux terminal and it will work. they both go back into the airhandler and power the same strips. w2 in airhandler to strips or w2jumper to aux w2 in airhandler to strips.but if otherwise, on your coil pack there should be two relays ohm them out if they are bad replace them. IF all this seems so difficult to handle i recommend call a well skilled techanician to handle it
May 11, 2011 | LG LMU360CE Split System Air Conditioner
The fan on my airhandler will not stop running i replaced the tstat did not fix problem
Check the relay that supplies the fan motor its voltage. Its common to have closed relays or stack type sequencers to get stuck and cause the component to run non-stop.
If you have the knowledge, its best to replace with a contactor that has a smaller failure rate.
May 16, 2010 | Heating & Cooling
Need to connect a universal fan relay with a transformer
I hope you are good at electric becaue you are biting off a chunk here...
Check out these diagrams they are for Honeywell but all the fan centers are pretty much universal...
http://customer.honeywell.com/techlit/pdf/60-0000s/60-2023.pdf
or this one...
http://customer.honeywell.com/techlit/pdf/60-0000s/60-2171.pdf
one of those should be pretty much like yours...
heatman101
May 06, 2010 | Carrier 38CKC036 Air Conditioner
New thermostat won't turn my system on
it is not wired right or while you were wiring it you dod not shut powere off to your a/c and you blew your contol voltage fuse in your airhandler
Aug 17, 2009 | Honeywell Programmable Thermostat Heater
Airconditioning will not come on
And if what jumptrout51 said does not work, remove the thermostat to expose the wiring and place a jumper between (R) and (Y).
May 24, 2009 | Honeywell Heating & Cooling
My honeywell thermostat says hold -AC on it and i can't figure out hgow to get the heat to come on now.
your tstat is not getting low voltage power from the transformer. check at the furnace or airhandler for high voltage and check the low voltage fuse
Nov 22, 2008 | Honeywell Heating & Cooling
MY HEAT PUMP SYSTEM WILL NOT WORK IN EMERGENCY MODE
the thermostat sub base has a place to connect a wire usually white to energize the heat strips when you push the stat way hotter than the house temp. that is why the strips come on in normal heat. it also has a terminal that is only energized in emergency heat and it also should have a wire connected to it so that terminal can supply power to the strips when the stat is switched into emerg heat . you can identify the terminal from the wiring diagram and if need be jumper w2 wire over to the aux terminal and it will work. they both go back into the airhandler and power the same strips. w2..................................................................................................w2 in airhandler to strips or w2...jumper to aux......................................................................................................................w2 in airhandler to strips.
Nov 10, 2008 | Amana PTH123B25AJ Heat Pump Air...
Installing thermastat
any wire can go to any terminal. unfortunately you now have to hand trace each onre to the device it powers and hook it up accordingly. a daunting task even for a pro. having said that the installer could have used the normal colrs for the usual wiring if you were real lucky. as a general rule the red goes to the r terminal. the yellow goes to the y terminal. the white on a heat pump usually goes to w2. the green powers the fan and goes to g. usually the changeover valve is powered by the o terminal and that is usually wired with an orange wire. that only leaves two more wires. one is the auxilliary or emergency heat terminal and any color wire can be used for that. it will go back to the airhandler and tie on to the w terminal along with the white wire from the stat on most units. or they may have jumped the w and emergency terminal together and hooked the white wire to both. it will work either way. that only leaves one wire and that is the common wire to the stat taht allows it to light up and think and have power. . most stats need the red and a common to work. you may have bought a stat that works off battery power only but since you are blowing fuses it seems you have a common pulled on one wire that you have hooked up wrong and it is creating a dead short , aka a blown fuse. if you go to airhandler and finf low voltage terminal board look for terminal labeled comm . observe what color wire is connected to it and if that is the wire that goes off to the stat. if it is hooked to common and goes with the others to the stat then thats your common and should be hooked to your stat common terminal as outlined in your install sheet. you can keep replacing those fuses till you get it right or take a chance and use an amp probe and a jumper wire . only run an instant and if amps are 4, 5, 6, amps at trans your wrong. only test an instant or you will ruin transformer.probably best if you get a box of fuses.label stuff make notes and good luck. i have gotten in the habit of using a sharpie pen to make copius notes right on the service panel for me and the next guy.
Oct 30, 2008 | Honeywell Heating & Cooling
Honeywell International Honeywell R8222B1067 General Purpose Switching Relay Logo
745 people viewed this question
Top Honeywell International Electrical Supplies Experts
Steve
Gene Haynes
Are you a Honeywell International Electrical Supply Expert? Answer questions, earn points and help others
