Question about Zanussi Washing Machines
Need a motor for a fl 812 machine 26 yrs old
Need a motor for a F L 812 machine 26 yrs old otherwise in excellent order
The price of new motor is €399 so i am getting a new machine , as it cost too much to fix my old machine .
regards kevin
Posted on Nov 17, 2009
How long does it take to drive from Sutton wv to panama city fl
Go to:
maps.google.com
In the window in the upper left corner of the web site, type:
Sutton, WV
Then in the little window below that, click on:
Directions
Then enter:
Panama City, FL
You'll get a map that looks like the one at this link:
Sutton WV to Panama City FL
It says it's 812 miles if you go through Charlotte and it will take you 13 hours and 12 minutes if you drive it straight. Any time you stop to sleep, eat, refuel, etc, would be added to that time, of course.
Feb 26, 2015 | Luggage & Travel
Maytag Neptune code fl shows on display
The FL code indicates that the door failed to lock when you closed it. Try opening and closing the washer door again. Make sure that there is nothing in the door area that could block the latch or keep the door ajar. If the error recurs, the latch may be faulty.
If the door is actually locked and giving the FL code, the latch has a problem. You can try power-cycling the washer (unplug for a while) or setting the washer to pump the water out. If these steps don't help, you need to order a replacement latch assembly. Depending on your washer model, you may have a manual pull cord to unlock the door. Look under the bleach and fabric softener compartments after opening the dispenser..
I hope this helps. If your washer is under warranty, contact Maytag. Otherwise post a comment with the model number of your machine for a source for a replacement latch assembly.
Oct 27, 2014 | Washing Machines
Sprint customer support
You need to be the account holder to change the number
Jan 29, 2014 | Cell Phones
How to thread machine
what is the name and model number of the sewing machine and I'll
see what I can come up with for you.
Dec 05, 2012 | Sewing Machines
Motor needed
You might be able to clean it and get it to work again. Take it out of the machine and make sure you know where the parts/washers, etc came from. You'll need to clean away any gunk from both ends and use a very fine grit sand paper to clean the armature commutator to a bright shine again. (90%) of the problems you've described are from a dirty commutator.
here's a nicely written tutorial on how do do this.
http://reviews.ebay.com/HOW-TO-OVERHAUL-YOUR-SEWING-MACHINE-MOTOR-IN-30-MINUTES?ugid=10000000004665359
Sep 23, 2012 | Sewing Machines
Calypso washing machine will not start... about 10 years old.. used to reset when i blew into the water level sensor - would show FL, then somehow rest itself.. not now it shows FL, can only get rid of the...
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%!#
Aug 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Model #DG210 serial #987926 It is 26 yrs old but
here is the web address and an 800 number where you can buy parts and they still carry the parts, however I do not think it is the jet I think it is the gas regulator bulb that controls the pilot light here is the web page and the 800 number where you can order for yourseldf and have it directly shipped.
Phne Numbers
1-877-477-7278
web page.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=27641
please rate if this was helpful.
Sep 13, 2009 | Dryers
My whirpol calypso washer don't running, appear fl and ce
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
• Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
• Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
• Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
• Drive motor thermal protector has opened.
• Motor controller is not powered or fuse has opened. Replace motor controller.
Mar 08, 2009 | Whirlpool Washing Machines
Hoover automatic 830 washing machine - leaking from under bowl
The water seal has been damaged. Will need to be replaced by a qualified technician.
Nov 03, 2007 | Washing Machines
Washing Machines Logo
66 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
