Question about Zapco Reference 750 Car Audio Amplifier
Zapco DC Reference 750.2 problem
So I go to turn on the car and I hear pop pop pop pop. All 8 of the high speed switchers on the amp popped. I have replaced them and now the amp fault light turns on, then off, then off, then off. Any idea what else is wrong. Or better yet, schematics?
  • 1 more comment
  • Hatters church organ
    Hatters church organ Nov 17, 2009
    Honestly, I don't know how to. I am good with a meter but rely on schematics. Can you give me some guidence?
    Hatters church organ Nov 18, 2009
    I will be out of town so I haven't had a chance to check.
    Some questions:
    Do I need to pull each one out of the circuit to test accurately?
    Will any old TIP35 and TIP36 do?
    How do they work together?
    I was looking at them in mouser and Digikey and didn't know if there was much difference from manufacturer to the next (BTW I understand the 35 and 36 are two totally different components, my amp had 8 of each).
    I can tell you how much this means to me. Hopefully by next week I'll get it fixed and walk away with a lot of experience.
  • Perry Babin May 11, 2010
    The amp likely has shorted output transistors. Did you check them?
  • 631 Answers
If the amp uses TIP35Cs and TIP36Cs, those will be the output transistors. Measure the resistance between legs 2 and 3 for each of the output transistors. Do any read near 0 ohms?
If you're new to repairing amps. The following page should help.
http://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm
Posted on Nov 17, 2009
I have no plasma display after hearing a popping sound
Sustain board fault. Check and replace the faulty one. Check the electrolytic capacitors at these boards. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 24, 2016 | Samsung 50 in. Plasma TV
2007 lexus is250 radio turns on pop in speaker and then no sound
have blown speaker some one turn it up to high and blew it replace it and what the volumne
Apr 19, 2016 | Lexus IS 250 Cars & Trucks
My 12 inch jl sub makes one loud pop when i shut off my truck off why is this?
The "pop" that you hear when turning off the system is caused be the amp not shutting down clean. This can be caused by several things -like a poorly designed or built amp. It can be caused by a poor chassis ground cable, poor line voltage coming into the amp, or a malfunctioning amp (if it didn't used to do this before). It may also be caused by the line-out signal coming from the head unit. If the head unit has a problem with the pre-amp section and sends the "pop" signal to the amp, the amp will just do what it's told to.
I would recommend starting with making sure that you have a solid power and ground connection from the battery and to the chassis. Next, I would try turning down the amp's gain if it's set too high and see if that helps.
Mar 05, 2010 | Jl Audio 12W3 Car Subwoofer
Subwoofer
turn on the amp and you know that the amp is good and you hear nothing
1. paralell wiring on speakers that are the wrong impedance very often will silence speakers to a eternal sleep along with that amp.
2. 4 ohm speakers mistaken for 2 ohm and are 8 ohm speakers mistaken for 4 ohm, the amp sees this load and it causes a overload on either side of the amp internal filter
( that's what makes the "pop sound") amp pops inside, literally makes a "pop" sound
you get a no sound
Oct 20, 2009 | Car Audio & Video
Popping and Humming noise from my audio system?
Ground Loop Isolators are nice, but if you want truly crystal clear sound, you will need to run a common ground. All electronics will need to be run close to the amp, as more than about 3 feet of ground wire from the amp can cause sound issues. When I ran my common ground, I connected my radio and satellite together, and ran one sigle ground wire to the backseat of my car, where the amp grounds are located. This will optimize the clarity of the sound coming through the speakers. For the popping sound in the speakers when the car is powered on or off, you need to see if the radio itself has a wire to power the remote connection on the amp. Most of the time, they will, and this is the wire you will use to turn on the amp itself, as it delays each item powering on and reduces the chance of popping in the speakers. DO NOT run the remote wire from the amp to the accessory wire of the radio, as this will cause the popping sound you are hearing. If the radio does not have an Amp Turn-on wire, then you may need to improvise by using an accessory wire in another location, but even this is may cause popping as well. The pop comes from multiple things turning on at once, so the Amp Turn-on wire delays the amps for just a moment, preventing the pops.
Oct 05, 2009 | Pioneer DEH-P6400 CD Player
Amp wont turn on, but i hear a pop when turning off
first off nothing should pop when turned off next it could be a grounding problem external or internal or worse an audio output problem take a volt meeter and turn key to on check the ground and positive on the amp should read 12 to 14 volts do same with ground and remote wire if these both read correct remove the back set your meeter to the diode setting the audio outputs are usually the larger ones but sometimes not take your leads and touch out side legs then to the outside to center try each one every way you can switching leads if at any time the buzzer stays on or goes to flat 0 then that output is bad if all check good i would go through the car making better connections and cleaning up any wires that might seem to be faulty maybe even replace your RCA cables
im running 18 speakers and 8 amplifiers in my car and i have done this several times :( but i don't pop unless something is wrong hope this helps
Jul 24, 2009 | Line 6 Spider Iii 30
Hello I bought Raidfire Spear, After 7-8 turn on-off problem pops
I am looking for extra smooth reflector and pill for my RAIDFIRE SPEAR
Mar 25, 2009 | Camping, Backpacking & Hiking
Reddy 10 breaker pops
check amp draw on unit if not high amps replace breaker
Jan 26, 2009 | Reddy Heater RLP100 Portable Forced Air...
Speakers pop when I turn the car off..
Most amps come with a soft start up that illiminates this problem... Im guessing that your amp does not have this feature and thats why you hear it. Read the manual and see if it states anythign about this.
Feb 14, 2007 | Alphasonik PMA600HC Car Audio Amplifier
Zapco Reference 750 Car Audio Amplifier Logo
442 people viewed this question
Top Zapco Car Audio & Video Experts
xxxxxx xxx
Are you a Zapco Car Audio and Video Expert? Answer questions, earn points and help others
