Question about Sony VAIO PCV-W1 PC Desktop
After 17 minutes operation there is always a complete (thermal) shutdown. The feeder fan does not work and has to be replaced. What are the costs? Sony VAIO PCV W1
  • Hanh Le
    Hanh Le May 11, 2010
    We can probably repair the fan but you'd need to send us your system for us to check it out thoroughly.
I found a local repair man myself.
Please cancel mij request.
Thank for ypur assistance
Hans
Posted on Nov 18, 2009
My gx620 thermal fan overheats
A) FOLLOWING Anti-Static Procedures;
1) Clean the inside of the computer out
2) Replace the Thermal Paste on the Processor (CPU)
THOROUGHLY clean top of CPU (Processor), and bottom of Heatsink.
PROPERLY apply fresh, new Thermal Paste.
http://www.hardwaresecrets.com/article/274
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503
http://www.dell.com/support/Manuals/us/en/19/Product/optiplex-gx620
Click on the blue ->
Dell Optiplex GX620 System User's Guide (5990KB)
Using Mini Tower Computer as an example;
In the list click on;
1) Removing the Computer Cover
2) Processor
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 13, 2013 | Dell OptiPlex GX620 PC Desktop
Always shutdown"CPU Shutdown Temperature
Hello download a manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=1093
Check the bios for any cpu overclocking settings
and set it back to standard settings.
Renew also the thermal cooling paste between the cpu and the cooling fan.
See if the cpu fan is running when the pc starts.
Be VERY carefull when you remove the cpu cooling fan
and take care not to damage the cpu.
And take antistatic precautions when you work on the mainboard.
If you have not tryed this before let a expert do the job.
Hope this will help you
Nov 22, 2012 | EliteGroup Computer Systems Ecs...
My Toshiba laptop shuts down after 5 minutes of operation - any ideas what could be the problem?
is it plugged into power and the power cable and converter are working?
if not take it in for a service
Mar 09, 2011 | Computers & Internet
The light is not working and the bulb is not blown.
These systems have many interlocks for safety. All doors must be closed completely. Also, there is usually a thermal fuse inside that may be blown. Did this stop during use or was it shutdown and now won't start again? If it was shutdown, perhaps it was unplugged before the fan stopped. If that is the case, the thermal fuse is likely to have been blown and will need to be replaced.
Let us know what you find.
Dan
May 13, 2010 | Chauvet Followspot 400g with Stand
My wire feeder keeps shutting off, how do i fix this problem
If the welder has a vent fan that doesn't work, it may be overheating with thermal shutdown. Look for a loose connection or intermittent relay inside the welder. If portable, check the power plug for a loose/broken connection. Hope this helps!
Mar 02, 2010 | Welding Tools
The system automatically shutdown
This could be anything, however I am suspicious of overheating. Does the computer actually just shut off or does it reboot?
Your heatsink/cooling fan may not be working correctly. See if you can install a utility which monitors the temperature of the CPU. If it keeps rising, this indicates a thermal problem and your fan and/or heatsink need replacing
Dec 04, 2009 | Microsoft Computers & Internet
WS55859 shuts off by itself after being on an hour or so, will turn back on after waiting 5 to 10 minutes
If the fan is running (they do fail fairly often), your power supply is progressing toward complete failure. Your description points to a thermal problem whatever the source.
Check fan operation first and if it is running, locate the power supply which will have the larger electronic components on it with several larger transformers and chokes.
Get the part number (if there seem to be two, the one on a label or stamped will be the completed board) and contact Mitsubishi's closest service center to inquire about the price of repair of the assembly or replacement cost. These may not be far apart.
Apr 02, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Power PC G5 Dual 2.5 sudden shutdown and no reboot
In G5 always the cover should be closed properly if not it will start the fan very fast like a blower and the red leds will be on showing that the heat is over so please check that the cover is closed and locked from behind so itworks smooth and the power supply is standard or normal
u should always use genune parts with mac..
thanks
Dec 19, 2008 | Apple Power Mac G5 Desktop
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Always shutdown my IBM ThinkPad A21m 2628 PC Notebook
It must be a processor overheating problem, check the vents are not restricted and if the fan is always on or never comes on because of a faulty temp setting then theres a overheating problem and the processor will shut down before any damage.
Oct 02, 2007 | IBM ThinkPad A21m 2628 Notebook
Sony VAIO PCV-W1 PC Desktop Logo
143 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
