Question about General Electric WHDRR418GWW Dryer
Ge Top load washer will not spin
Ge Top load washer water will come in, but will not spin .
  • 10 Answers
SOURCE: Ge whdsr315 top load washer will spin but not
Sounds like the nut that holds the agitator on to the shaft is not tightend down or the agitator is not fully "locked" into place on the shaft.
Posted on Sep 13, 2009
jumptrout51
  • 3361 Answers
SOURCE: ge washer
Pull up sharply on the agitator to remove it from the shaft. Check the agitator mounting cup underneath it is probably stripped out. It is a replaceable part.
If the agitator is difficult to pull up,use a old strong leather belt under the agitator and pull it off using the belt.
Posted on Nov 08, 2009
  • 289 Answers
SOURCE: My Top Loading GE washer will not agitate
nead the mod#
Posted on Jan 19, 2010
  • 11 Answers
SOURCE: I have a GE whdsr209 washer. Stuck on filling with water.
Ok, take a deep breath and blow....
No, really...
Ok, to understand how to fix the problem you have to understand a little bit about the control part of the machine.
Ok so here we go...
First thing is the first stage which is filling the machine with water.
So how does the machine know how much water to fill, well the answer is pressure.
If you remove the front panel of the machine and look on the side of the tub, you will see a tube attached to a plastic hull.
Air gets trapped inside the hull and as the water fills the tub the pressure inside the hull increases. The tube attached to the hull routes the pressure building inside the hull to the fill pressure switch. The more water filling the tub the more pressure generated and supplied to the switch.
If the line becomes clogged with buildup or developes a leak, the whole process will not work, thus the switch will not become engaged stopping the flow of water into the machine.
How do you check for opperation of the line and switch,
well remove hose from hull and as the tub is filling with water, blow into the tube creating pressure and thus activating the pressure switch..
You will hear the switch click and the machine should stop the fill process and start washing.
Rarely but possible, the pressure switch is faulty.
Mostly, it is a clogged line, disconnected line, or line that has been damanged by rodents or pets..
Hope this helps
Good luck...
Posted on Jul 28, 2010
  • 142 Answers
SOURCE: the ge front load washer
It has a separate water pump. Probably something got stuck in the pump and keeps it from turning and pumping the water out. You should be able to remove the bottom front to check that.
Posted on Aug 09, 2011
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
GE Profile Washing Machine wont fill with water top loader
disconnect water lines from washer and check to see if sedement from water plugged up little screen filters
Jun 11, 2009 | GE Profile WPRE6100G Top Load Washer
GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
Jun 08, 2009 | GE WBSR3140DW Top Load Washer
Washer filles with water can hear timmer then drains never spins
you have transmission problems. When your washer is empty and off you should be able to turnthe agitator by hand if you can't then the transmission is bad.
Apr 03, 2009 | GE WDSR2080D Top Load Washer
Ge washer not draining or spinning
HI yes you can remove the pump and clean. the pump is the problem
Oct 12, 2008 | GE WBSR3140DW Top Load Washer
GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Aug 23, 2008 | GE WHRE5260E Top Load Washer
GE Washer top-load WLDSR416FOWC
Actually, I think I do remember having one do this before, and I believe on these GE models the spin cycle goes through the water level switch, so if your water level switch is sticking, then it won't spin, thinking its still full of water.
Here's the water level pressure switch for your model:
Manufacturer part#WH12X10065 is RepairClinic item#2205
don't forget to rate me in main page,it is the only way i get paid for my works..
Jul 23, 2008 | GE WDSR2080D Top Load Washer
General Electric WHDRR418GWW Dryer Logo
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
