Question about Garden
I have a Craftsman 18'' 45cm chainsaw and have a broken spring inside the housing. I need an online manual - could you possibly help me with that. Thanks;
  • dontbother10
    dontbother10 May 11, 2010
    Try Craftsman first, it was probably manufactured by Poulan. If you find out which model Poulan it is and give us a little more detail most of us are quite helpful. Lou
clyde2j2
  • 137 Answers
SOURCE: need to rewind craftsman chainsaw pull rope.
I have tried to do this many times and have yet to suceed, believe me it's not worth the fustration and the extra days in hell you will spend from cussing.
Take to a repair shop, they can do it quickly and cheaply when you consider how difficult this is for the ordinary person. (me)
Posted on Mar 02, 2009
SOURCE: Spare parts for a Spear & Jackson chainsaw
I had the same problem
contact www.einhell-uk.co.uk
with ref: SPJCS3740
thanks
Posted on May 05, 2009
dontbother10
  • 2220 Answers
SOURCE: broken recoil spring
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Lou
Posted on Sep 05, 2009
dontbother10
  • 2220 Answers
SOURCE: lost my manual for my poulan pro 255 chainsaw the
If looking for parts your OM is of little value. You can find an IPL (exploded parts list) here (only one PP255 listed):
http://www.ordertree.com/modelinfo/PWE/PP255-Gas-Saw/75.PP255-Gas-Saw.1.59.1.html
Rear vibration (isolation spring)s appear to be item 5 or 59 on the "Exterior Assembly" print.
Poulan replacement OM.
http://72.3.225.179/manuals/87722e.pdf
There is contact us number in the OM if you want to contact Poulan. HTH
Lou
Posted on Feb 15, 2010
Testimonial: "thank you very much for the information that you sent me. i spent two hours on a dial up modem trying to find the part and 20 seconds to read your rep"
dontbother10
  • 2220 Answers
SOURCE: I bought a second hand Craftsman 33cc chainsaw and
I was THAT close. Lou
Posted on Mar 17, 2010
How to recoil the spring on a pull start cord for a craftsman pressure washer model # 580 750 400
If no repair manual. It could be spring is broken. So I'd look for spring, and instructions to install spring. That should give you a good idea. I suppose the handle came off and lost the rope inside? Probably need new rope too. Same kind of instructions would apply in how to recoil if it's not broken.
Mar 13, 2015 | Craftsman Garden
Recoil will not retract
its one of 2 problems. a: you have jammed it when you pulled on it or b: the spring has broken. simply take a spanner and undo the pull starter housing 1-2 turns and tap the chainsaw on the ground while flicking the cable tight and loose. and if that doesnt work try a flat bladed screw driver to see if theres tension inside the housing by trying to turn it back towards recoiling.. if it doesnt at least un jam you may have a broken spring. which means a trip to the tools shop to see if you can get them to replace it. or if your courageous take the whole housing off and see if its broken or not (watch out in case your pull starter features a rather nasty long flat piece of wound up spring steel that likes to come out of there at a pace fast enough to take an unwary eye out)
Sep 19, 2012 | Stihl Garden
How do I install a recoil spring ?
Sometimes the hook at the end of the starter spring has broken off from rust or has straightened itself out. What I do if I don't have time to get a new spring is make myself a hook and attach it to the notch. Then you have to manually wind the spring in the right direction and hope that the spring doesn't unravel on you. Wear safety goggles for that!
If I need to get it started without the recoil spring, I just wrap the starting rope around the engine and start it that way until I have time to get a new part.
Jun 14, 2017 | Briggs & Stratton Garden
How to change pull spring
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly. HTH
Lou
Oct 29, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Pull cord stuck in the out position
this can be caused by sevral things inside the pull cord hub assembly. examples: Dirty inside & needs taken apart & cleaned. something logged inside, plastic spool tabs broke, spring/s broke, levers broke or any of these items could just be to worn. replacement parts should be available.
Oct 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Craftsman gas chainsaw 18'' model 358 pull start repair
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Sep 20, 2009 | Garden
with ref: SPJCS3740
thanks
Apr 21, 2009 | Husqvarna Chain Saw 20" Bar
Broken recoil spring
Lou
Mar 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan starter rope
to fix starter rope first you must wind spring and place back in housing. just grab spring by middle and wind ,you will have to get it smaller than housing hole. One end should hook to a tab at housing rest of it sets inside itself. once set in housing dont let go, insert rope housing over top & screw in. rope housing should have some return spring to it when pulled. if rope is not tight on return pull simply add one winding to spool. hope it helps!
Feb 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Broken Pull String
Yes, it is possible that the spring needs to be pre-tensioned. its also possible that something was put together a little out of alignment, or some part is too tight and its too hard for the spring to wind in the chord. try to reassemble the chainsaw with a couple more turns on the spring and see if that helps.
paul
Oct 30, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
