Question about Samsung S1070 Digital Camera
Samsung S1070 silver, White lines across picture when taken in daylight night time/flash ok??
Im havin the same problem someone please help i need to use it for a weddin on sat!!!
s.davies92@hotmail.co.uk
Posted on Sep 13, 2010
How to get rid of white lines on my Samsung L 700
Posted on Aug 29, 2011
The flash dont work in samsung s1070 plz can u help me? ramy_donjewan@yahoo.com
Posted on Dec 20, 2009
2 Suggested Answers
SOURCE: my samsung s1070 camera ,
lcd white
Posted on Jun 21, 2011
My samsung s760 has ahorizontal lines when you shout in a day time but if you shout it it evening the picture is ok.eventhough i put off the flash in day time it is the same result.what can i do?please...
Mary,First check to ensure that your camera is in automatic mode, and not in one of its manual modes. For example, shooting in a night scene mode in daylight could cause these symptoms. But if you are in auto, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 11, 2011 | Samsung S760 Digital Camera
SAMSUNG S1070 - When I take pictures, white lines appear on them. They don't appear on the screen when I am not taking a picture, and they do appear when I transfer them to my computer. I have tried...
How do outdoor pictures look when taken with the camera? If overexposed, first check that your camera is in automatic mode, and not some other manual exposure mode of the camera. Next, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
May 29, 2011 | Samsung S1070 Digital Camera
When i take picture,the picture is white n some time become very very bright, but if take video is ok.
this can be usually associated with your white balance in still camera mode.
Check to see your white balance is set correctly or just set it to auto. Also make sure the mode you are in it set. (ie. indoor, outdoor, auto, speed)
May 04, 2011 | Canon PowerShot A460 Digital Camera
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear..
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Dec 21, 2009 | Canon PowerShot A470 Digital Camera
Problem on outdoor daylight picture taking
hi
try the Exposure button [+/-] will generally be disabled in auto mode
try changing mode to 'P' (Program) mode and then change the exposure by pressing the +/- button and then you would generally see a scale on the LCD now press the left button to decrease the exposure
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and otehr settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
Jul 03, 2009 | Samsung Digimax L60 Digital Camera
Fotos are white
Try the video. Is it ok?
Adjust the zoom so the internal lens is up close to the outside lens. Now, look into the lens at an angle so you can see into the lens without reflection. With the flash "off" so as not to blind you take a picture and watch the shutter close over the lens. Did it cover the lens? If not then something is obstructing it or there is an electrical failure with the electro magnetic switch operating the shutter.
Apr 24, 2009 | Fuji FinePix S6500 Digital Camera
So much light on picture
Hi, Mark here see if I can help.
Sound like your camera is set to night photography.
Try resetting it to Auto or sports when shooting in daylight.
Hope this fixed ya! need more help comment back.
Please rate. Good Luck!
Mar 28, 2009 | Canon PowerShot A450 Digital Camera
Blurry white image when pics are taken during broad daylight
Try first to reset your camera. Press the menu button, go over to setup, go down to reset, press the right arrow, highlight reset and press set. Don't worry it won't erase any of the pictures on your memory card. If that doesn't work you can try and manually set the white balance on your camera and I would recommend sending it into repairs if that doesn't work since it's taking nighttime pictures fine. :)
Dec 07, 2007 | Casio Exilim EX-Z55 Digital Camera
Samsung S1070 Digital Camera Logo
732 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
