Question about RCA P52926 52" Rear Projection Television
RCA Rear projection Tv D52W25
My 2 years old rear projection tv has a loud gas leaking sound that sometimes sound like if sparks are making explotion. I open the rear to see from where it is coming out, and I found a red wire connected to a like car coil part with a rubber cover is the source.
There is a blue flame coming out of that part and when get in contact with another part beside its, make sparks and sound like an electrical short
  • philo2008 Jan 30, 2008
    I own a 2004 rca 52in. rear projection model and have a similar problem.
    The component is the high voltage regulator found on the left bottom part of the set if you are looking from behind. Mine is at the point where, even with the power not being switched on, it start to arc and screech after about 15-20 seconds. Thankfully one of the fixya techs diagnosed it as being the high-voltage regulator (or flyback transformer). The part is $50-$70. Since I'm not capable of soldering a new one to the motherboard, I recommend buying the part and have a qualified technician install it.
  • 4,402 Answers
The would be you high voltage flyback do not run the set while this is happening as it could do more damage.
you should replace that part.
Posted on Jan 09, 2008
I have a rca d52w20 rear projection tv that has sound but no picture what may be the problem
When was the last time the tv projection lamp was change in this tv?The projection lamp in the tv now,if 1 1/2 or 2 years olds,tv on an in uesd like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.Hear alot of clicking too?The board call the Ballast board also require changing.This Ballast board help to ingnite the projection lamp.
Aug 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lost picture
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
TV makes very loud noise
Ur high voltage transformer is dead,the FBT,the big block of plastic have red wire go to the video board.Also might have burns capacitors in the DM power suply board or deflection board it puffed up.
Sep 28, 2009 | RCA HD52W58 52" TV
RCA P60921 60 in. Rear Projection not working
could be the flyback as some eat them depends on how old it is, and what model it is be more specific. also possible high voltage divider box
Nov 11, 2008 | RCA P60921 60" Rear Projection Television
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
Loud Buzzing Sound
Sounds like the cooling fan blades are hitting something (possible worn bearings).
Apr 21, 2008 | RCA P52926 52" Rear Projection Television
Sometimes a part can go shorted, and an over voltage occures somewheres thus causing another part to blow. This can be anywhere from in the power supply to any of the other boards.
The set would have to be serviced to determine the cause and what was damaged. Most likely there will be the need to change some boards. Most of the service is done by a combination of board replacement and some component replacement depending on the exact type of fault.
Jerry G.
Apr 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hd61lpw42 rca tv
I also have an issue w/my RCA rear projection TV making a piercing sound. My TV does not do it on the HD channels, but does make the noise on the regular cable channels and on On-Demand as well.
Dec 27, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Loud electrical sound in rear of set(tv)
Sounds like the High voltage is leaking out and arching somewhere. Have a look in the back and see where it is BUT be CAREFULL!! This is enough voltage to cause serioud harm to you. If you have no TV repair experience, this is not the repair to start experiementing with. Play it safe and call out a pro to assist you. Good Luck.
Mar 31, 2007 | Zenith R40W46 40" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
99 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
