Question about Whirlpool Calypso GVW9959K Top Load Washer
Does whirlpool Calypson GVW9959KQ2 have an active recall on the pump?
My calypso GVW9959KQ2 displays L5
its probably LS not L5 code,which is a lid switch failure and this will result in a machine that will fill and possibly agitate,but wont spin out.replace lid safety switch located underneath top of units outer case
Aug 01, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Where can I get a User/Owners Manual for Whirlpool Washer, Calypso Model # GVW9959KQ2
My buddy Robert and me got into a couple of these washers; an older one and a newer one. I took some photos and included your manual HERE and HERE
Mar 07, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My whirlpool calypso washer just quit working no codes no power just dead. GVW9959KQ2
Won't Power Up
  • 120VAC electrical supply.
Check voltage supply to washer.
  • Open AC cord.
Check for voltage at the power cord connection to the line filter.
  • Line filter open.
Check voltage into and out of line filter.
  • Machine control board open.
With the washer off but connected to the AC outlet, measure the AC voltage between Pins 4 and 2 at connector P16.
Dec 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Whirlpool Calypso washing machine, model
communication error. changing the MCU. sometimes a bad pump could be the problem
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Mod: GVW9959KQ2, stops and shows "ob" as code for fast final spin. Also making high pitched whine during wash cycle. Appl svce place has suggested bearing or xmission. Any possible...
Sorry to say but they are right. The Calypso washer was a horible design given to whirlpool from maytag. I would suggest you go buy new machine. Buy someting that looks simple and easy to use. The more complicated the unit the more problems you will have down the road.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't drain. believe is it clog or inop. model gvw9959kq2 would like to have some type of machanical or electrical systematic
whirlpool front load? Rmove bottom panel ckd pump to if it is at least humming if is get as much water from iside if possible lean unit back to keep water from tub outlet remove clean port plug by turning counter clockwise clean pump and ckd impeller to be sure it's turning free reassemble and ck
May 01, 2008 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
214 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
