Question about Siemens Washing Machines
Siemens UltraSense Front Load washer spin cycle problems
I have a Siemens UltraSense Front Load washer. On several occasions, but not all, after all of the cycles are finished, the washer beeps, but the clothes or sheets are still heavy with water. Even if I use the spin cycle again 2-3 times after, clothes are still dripping wet. When I re-start just the spin cycle, I do notice that the drum is not moving as fast as I think it should. Any advice as to what may be wrong?
  • 10 Answers
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
Posted on Aug 22, 2008
IrishDruid
  • 2712 Answers
SOURCE: Spin cycle not working properly, clothes still wet!!!!
When the clothes are wet at the end of a cycle, check these:
Motor coupler Totest the motor coupler, re-start the washer in its spin cycle. Let themachine run for a minute, and then open the lid and notice whether thetub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • Ifit isn't spinning--and your machine was produced by Whirlpool®--you mayhave a broken coupler. Many Whirlpool-made washers use a small,relatively inexpensive device called a motor coupling. Thisplastic-and-rubber component is mounted to the shaft of the motor onone side, and to the transmission on the other. Over time, the couplerwears out and fails. When that happens, you need to replace itcompletely.
Spin cycle Ifthe washer doesn't reach its proper spin speed, the clothes may be toowet at the end of a cycle. Check to be sure the load is properlybalanced and run a spin cycle again. If the clothes are still wet, youmay have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®),or a worn motor pulley or tub bearing. Replace the applicablecomponent.
Alternatively, there could be clothes caughtbetween the inner and outer tubs. Read the "It spins but won't pump"section of the "It won't drain" section. Also, there could be otherthings that cause friction on the drive train. Seek the assistance of aqualified appliance repair technician.
Siphoning Ifthe water that pumps from the machine goes right back into the machineafter the spin cycle, it may be because your washer is siphoning thewater from a laundry tub with a slow drain, back into the washer. Tryto improve the draining of the laundry tub. (Is there something stuckin the drain?) Also, be sure the drain hose doesn't reach more thanabout 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inletvalves eventually fail. One problem that may develop with a water-inletvalve is that it can no longer completely shut off when the electricityis turned off to it. Then, the valve may leak and drip water into theclothes tub--you may notice that your washer has water in it when youhaven't used it for a few days. To fix this, replace the valve.
More information can be found here:
http://www.repairclinic.com/0088_11_1.asp#Level1_12
Posted on Oct 29, 2008
  • 68 Answers
SOURCE: Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Posted on Jan 17, 2009
  • 7 Answers
SOURCE: MY ADMIRAL WASHER WONT SPIN FAST ENOUGH..IT DOES SPIN BUT WHEN IT STOPS THE CLOTHES ARE STILL DRIPPING WET
Sounds like a whirlpool or inglis type belt drive with a loose belt or bad basketdrive[clutch].
Could be the set screw backed out on the basket, thats a pretty common problem.
I'd need a model number to know who made it though.
Posted on May 19, 2009
Whirlpool 6AWM8143 Front Load not starting spin cycle
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 04, 2010 | Whirlpool AWM8143 Front Load Washer
How do I get rid of mildew smell in Siemens UltraSense front-load
Siemens
WFXD8400UC Front Load Washer
This video will show you how to change the door seal gasket on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 17, 2010 | Siemens WFXD8400UC Front Load Washer
''Check water tap'' readout
Check you running water to the inlet.
Apr 02, 2010 | Siemens UltraSense 3.7
Error code E:13 is showing on the washer
Mine did it too on a light load. Set to reduced spin and rinse spin and everything ok. Think this code shuts washer down when spinning out of balance to protect damaging the unit.
Mar 21, 2010 | Siemens WFXD5202UC Washer
Where can I purchase new screws for moving my Sieman's Ultrasense frontload washer?
your best bet is siemens web site get their contact page and call them for a dealer phone #
Dec 09, 2009 | Siemens WFXD5200UC Front Load Washer
Siemens stops without going into the spin cycle
when it stops is there and f:XX error code on the display? were XX is a number.
Jul 18, 2009 | Siemens WM14S794GB Front Load Washer
Where can you purchase Siemens parts in the USA? We've just begun our search for a drain pump for our WFXD5200UC UltraSense Washer. Thanks
www.apdepot.com
they are very reasonably priced. If you don't find the part on their website, call them.
I just purchased that same part (drain pump assembly) for about $ 63.
Now I have to find out how to access it to replace it!!
May 16, 2009 | Siemens WFXD5200UC Front Load Washer
Bad Musty Moldy Odor in Washer
Run a wash on the highest temperature, and add some vinegar into it. May do this more than one time. Be strict to wash on the higest temp some times in the month.
Good Luck
Jan 24, 2008 | Siemens WFXD8400UC Front Load Washer
Washing Machines Logo
332 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
