Question about Jura Capresso 553.01 Electric Burr Grinder
Good morning. My Capresso Burr Grinder Model No. 555 is way off in calibration. How do I repair this? When set to "1" on the dial, it's grinding coarse.
SOURCE: grind setting
This grinder is really pretty crappy, I have the same one. If you want anything less coarse, you will have to grind it multiple times. My Grandmother tried using this and it ended up spitting out a few half and whole beans even after grinding. The best you would end up getting would be a drip coffee grind. Check this out, it might help understand the problem: http://www.epinions.com/content_143707967108
Posted on Jun 26, 2008
SOURCE: does not grind
Sorry no answer ...i have similar problem described
Mine... sounds like it is working but nothing grinds. Any suggestion no this issue
Posted on Jul 11, 2008
SOURCE: Cuisinart DBM-8 Grinder Automatic Burr Mill stopped grinding
perhaps remove the hopper (top) and inspect to see if a buildup of very fine compacted grounds as accumulated. knock the stuff loose.
Posted on Mar 28, 2009
  • 1089 Answers
SOURCE: all of sudden my grinder plugs up. coffee settles
If you can adjust the bean hopper to the coarsest grind setting and try again. If that doesn't work, remove the grounds drawer and vacuum the inside top where the grounds drawer was. You have a blockage above the grounds drawer.
You can also rotate the bean hopper counter clockwise and lift it off. Remove the outer burr by lifting it out. Vacuum the grounds out from both sides( burr side and grounds drawer side) probe the opening to remove any packed grounds, then reassemble. The bean hopper has 2 tabs on the bottom. 1 large and 1 small. Make sure that they go in their respective place.
If you cannot rotate the bean hopper? Remove the beans and ground hopper. Turn the machine upside down and then gently rotate the bean hopper back and forth until it will rotate completely (270 degrees). This will shake out any grounds in the threads. Do not force it as you can break the tabs that rotate the burr adjustment.
Posted on Nov 03, 2009
SOURCE: Krups GVX2-12 Electric Burr - Thermal Fuse
My grinder stopped suddenly. Open the cover(s) by prying at the cracks with a butter knife or flat head screw driver.
The thermal fuse was good in my case, as were the interlock switches.
The circuit board was burnt around a large power resistor but I could figure out which component was bad. I simply cut out the timer control completely. One of the black motor wires now connects to the red wire from the bottom interlock switch and the other black wire connects to the blue AC power wire. I may put in a button switch but it works great by using the lid interlock as an on/off switch.
Posted on Mar 16, 2010
The bean container/hopper on my Capresso 560.01 Infinity Burr Grinder is stuck and can no longer be rotated in either direction or removed from the body. Can anyone help me unseat it?
Grinders that are used daily, especially those in coffee shops will eventually wear out. The fine settings for espresso (or even finer for Turkish grind) will wear out the plates even faster. I've seen burrs needing replacement in 3-6 months for coffee shops. Burrs set on this fine position that do not grind or stop usually means a worn burr or gummed up plate. (especially with oily beans). Either problem requires the removal of the burr set and complete disassembly of the grinder. It sounds like your '1st' problem was corrected by permanently 'affixing' the burrs to a set position and now not able to remove them without causing more damage. I did the same to an old grinder I got from the swap meet. But alas, the plastic collar cracked completely and can't be repaired. well got 1 year's worth of use and it was cheap.
** Suggest checking with your vendor or MFR for service and/or replacement.
Aloha, ukeboy57
Dec 08, 2017 | Coffee Makers & Espresso Machines
Grinder stopped working today. Tried to clean with no result. Anything I can do to trouble shoot? The timer goes, but no grind...
check to see if the grinder is jammed. Most likely, there was something that's gotten caught in it, and jammed the mechanism.
Feb 27, 2016 | Jura Capresso Capresso Infinity Conical...
Why does ground coffee not go thru shoot
If using Beans; it is set to fine and due to static it sticks - OR you have a blockage..
If you are putting ground coffee into a grinder; the static will be a bigger issue and in addition there is no weight from the beans to press the grinds into the burrs. A bean grinder is not ment to grind beans that have already been ground.
Get a better grinder and do not buy supermarket beans.
May 31, 2014 | Capresso 560.01 Infinity Burr Grinder,...
I cannot adjust the grinds its only cming out fine even if I turn the screw in the center
You should call your vendor for service.
*** The following is for information only. Service should be done by a qualified tech.***
* Check bunn.com for a free download of the G3 manual
* If turning the dial does not change the grind size then the inner burr spring is broken, stuck, of missing (it broke into small pieces to fall into someone's coffee grounds). Call vendor for service.
* If turning dial is very loose then the lock screw is loose. check setting then tighten down to lock into place. It's usually a small 1/4" hole on the side of the knob.
* The burr plate may be gummed up and stuck in place. Especially if oily beans or 'flavored' beans were ground in this machine often.
* It's possible the Grinder is WAY out of calibration. It's so far out of adjustment that the only setting is fine when the dial is set on course ground. This grinder was not assemble correctly. Check the parts diagram. Call your vendor for service.
Aloha, ukeboy57
Jan 18, 2014 | Bunn -o-Matic G3 (3 lb. Commercial Coffee...
I took everything apart to give it a good cleaning and now all settings produce a very fine grind. Any thoughts?
I had the same problem with too fine a grind when I took mine completely apart to clean (including the lower burr). The solution I finally came around to was to further tighten the star-shaped screw which holds the lower burr assembly in place. I had originally just tightened it until the lower burr until the lower burr assembly started to turn with the screw, but that wasn't enough. So I held the assembly in place and tightened the screw further and I'm back to my previous grind coarseness/fineness.
Jan 13, 2014 | Jura Capresso 560 Electric Burr Grinder
Our DGB-700 has stopped grinding the beans. The motor sounds very weak. I have taken it apart and cleaned thoroughly with no good results. Can it be repaired or is it just time to "move on"...
I use Capresso CoffeeTeam model #454 10 cup 50 oz digital coffeemaker burr grinder combination with four grind settings. Now it is more than 5 years old, works every single day without any problem. Capresso has the great customer support. Its price for the refurbished item is compatible with the price of your Cuisinart. I am not sure it is the solution for you but I am very happy with my coffeemaker.
Jan 04, 2011 | Cuisinart Grind Brew DGB700 12Cup Coffee...
Whatever the setting is at the grind is always fine. What can I do to re-calibrate the grinder?
Grind Adjustment Tools required: Large blade and medium Phillips head screwdrivers In order to adjust the grind, follow these steps (Refer to figure A): 1. Remove all coffee from the hopper. 2. Set selector knob to the finest setting (Espresso or Turkish) depending on the model. 3. Loosen both knob retainer screws in selector knob one turn only. 4. While pressing the bag switch, located behind the spout, press the START button so that the grinder will run during adjustment. 810 model - Press the ON or START button so that the grinder will run during adjustment. 5. With the grinder still running, turn the adjusting screw in the center of the selector knob slowly to the right until a slight clicking noise is heard. Immediately turn the adjusting screw to the left one grind setting. This is the finest grind obtainable. 6. Tighten both of the knob retainer screws. Once the ESPRESSO grind has been set (Turkish for Model 835, 875, 890), the other grind settings will automatically set correctly. 7. Press the STOP or OFF button. IMPORTANT: Always be sure the grinding burrs are not touching while the machine is running on the ESPRESSO/TURKISH setting. Otherwise serious damage to the motor may result. dr_buckhead.png
Nov 19, 2010 | Grindmaster 810 T Electric Burr Grinder
Spring loaded ball bearings - does the ball bearing sit on top of the spring or below the spring??
The ball bearing is a check valve. The ball should be in the input side of the water with the spring underneath.
input side ----->( O/////)-------> output side
Feb 21, 2010 | Jura Capresso Capresso Infinity Conical...
My Solis coffee grinder does not go a fine grind any more. We
Hi
Your grinder adjustment ring inside has its tabs broken. Contact Baratza at 877-701-2021 and they should be able to help get a new one.
Nov 15, 2009 | Solis Maestro Electric Burr Grinder
Grind setting
Jun 17, 2008 | Jura Capresso 551 Electric Burr Grinder
Jura Capresso 553.01 Electric Burr Grinder Logo
46 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
