Question about Ducane 455 inch 2 - 3 Burner with rotisserie Grill
I was given a ducane 20002301 2 burner with rotisserie and when I ignite and have on high there is not much flame. I know very little about gas grills
    Champion:
  • 274 Answers
Could be two things, the first is a bad regulator, easy to replace and not very expensive. The other is a blockage in the burner orifices. For this you have to take the burners out and check inside the burner venturis and then see if you can unscrew the orifices on the valves and clean out any blockage.
Posted on Jan 12, 2010
Have a home depot ducane 5 burner. just replaced burner tubes. have never used the rotisserie burner on it before. it lights but won't stay lite after releasing knob...any suggestions? Thanks
Infrared burners requite that the gas control knob be held in for 2 minutes or so, to allow the thermocouple on the infrared burner to heat up completely. If it's windy were you are, the wind can blow the burner out, while trying to light it. That's why it has a thermocouple on it, to stop the gas if the burner goes out. All cooking on the rotisserie is doon with the lid/hood closed, at temperatures around 250 degrees F. Once the infrared burner turns bright red, release the control knob.
Hope this helped you to get it lit. Thanks for choosing FixYa.
Aug 24, 2011 | Ducane 30400040 Stainless Steel Grill
None of my igniters on my 30400043 Ducane grill will light the burners. I've had a grease fire due to the burners rusting out and replaced the burners. The insulation on the wires to the igniters has...
As I tell customers, when they ask me, "How long will this grill last?" "That depends on well you take care of it with routine maintenance and cleaning."
The wiring for the electronic ignition and the spark ignitors are replaceable. The ignitor button or the "clicker" as you called is replaceable. But all you may to do, is change the battery inside the igniter button. To help you further, i have included a link to the Owner's Manual for your grill. It will have an exploded view of the parts, which should help you identify them by part number and order them from Ducane, if you like.
http://help.weber.com/manuals/ducane/2008%20Manuals%20pdf/20529916_030308.pdf
A far as the infrared burners are concerned, they blow out easily if the wind is just blowing slightly. That's why they have a thermocouple on the burner, to turn the gas off to it, when it gets blown out. When preheating an infrared burner, the hood/lid of the grill should be closed.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Ducane 30400040 Stainless Steel Grill
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
CalFlame 4-burner convection BBQ rear rotisserie burner does not work. Converted to natural gas. There is a spark but gas will not ignite. Held match to burner and it would light but would go out when...
Check the air shutter adjustment on the rotisserie burner. It may be starving for air. Also make sure the burner is properly positioned over the orifice. When it was converted, it may not have been put back into place correctly. Also, it's possible the orifice may have been re-drilled out at the wrong size for natural gas. If you know the rotisserie burner BTU rating, I can look up the correct orifice hole size to check if it's right. Douglas
Sep 12, 2010 | Cal Flame 5-Burner
Rotisserie burner won't light
It could be a dirty or inop spark electrode. Also could be weak batteries in the spark igniter.
Before you start you should make sure that the ignition system has fresh batteries. The batteries are usually located within the igniter button but not always. Some BBQs will have a battery pack located somewhere on the BBQ and others you can remove the igniter button by turning it left to reveal the battery.
First verify that the rotisserie burner can be lit manually. Take a BBQ lighter or long stick match and then put the flame right at the base of the burner where the electrode is and then slowly turn on the burner valve. It should light within four seconds. If it does not then shut the burner off and check for any restrictions in the gas line for the burner.
If it does light with a match then the spark electrode could be dirty, out of position or simply the wire for the ignition system is loose. Press the igniter button and watch the electrode for a good bright spark at the burner. If you do not see any spark you can verify that the igniter wire has not come loose and also gently adjust the position of the electrode end a little bit closer to the burner using a pair of needle nose pliers(It should not be touching the burner). It does not need to touch the burner but have a really small gap.You can use a small wire brush to gently clean the electrode of any debris that might be causing a weak or no spark
If you are unable to remedy the non-spark issue all is not lost. You can still use the manual lighting procedure I described to light the burner. And remember to be careful when trying these procedures. I do not want you to get injured from delayed gas ignition. Be careful and have a safe holiday.
Jul 04, 2010 | Ducane 30400042 (LP)
One burner on the Ducane gas grill lights only weakly. Gas is coming through but only some of the holes ignite. The other side is uniformly lit, but the flame only goes maybe 1/4" high. Clues?
try opening the tank really slowly. the tank has an overfill protection devise built inside and if it is opened too quickly it can restrict the gas flow to the burners. hope this helps.
Sep 14, 2009 | Ducane Grilling
Cannot light new burners
I just replaced my burners and I also cleaned the starters. Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.
Jun 02, 2009 | Ducane 30400040 Stainless Steel Grill
The burners sounds like a jet plane.
make sure the burners are clean, each and every little hole must be clean. It sounds as though the flame is burning near the inlet of the burner which can occur if the holes are restricted too much.
May 26, 2009 | Ducane 455 inch 2 - 3 Burner with...
Lighting Problem/2 year-Old Ducane Grill
Do you have enough gas pressure coming out of the regulator and gas valve? You'll need a pressure guage for this.
If yes, try taking out the burners and cleaning them with a wire brush, especially the flame spreading sections.
Sep 15, 2008 | Ducane 30400040 Stainless Steel Grill
Ducane 3400042 lighting problems
Good answer... but remember (if you have the regular burners on... The Rotisserie will not light.) 1. Cut all knobs off... Then push and hold in Rotisserie button as you turn to high.
2. Press ignition button, until you hear rotisserie ignite. 3. Keep holding in the rotisserie button until the thermostat realizes the gas is on and burning. (IT must get hot enough to keep gas flowing.) Hope that helps, Dave
Apr 08, 2008 | Ducane 30400040 Stainless Steel Grill
Ducane 455 inch 2 - 3 Burner with rotisserie Grill Logo
154 people viewed this question
Top Ducane Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
