Question about Sunpentown 1000W Port Gas Generator
No power to ac outlet 120 volts - Sunpentown 1000W Port Gas Generator
  • 317 Answers
Find out where the fuses are and check em
Posted on Nov 17, 2009
Power from electical outlet to power a travel trailer,AC,MW,LIGHTS 110to 220
all trailers use 120 volts a 30 amp cord 3 pronged is wired a hot a neutral and a ground a 50 amp cord 4 pronged is 2 lines of 120 volts but its not 220 volt it has 2 separate 120 volt hot lines a neutral and a ground you should see a dealer to explain for safety
Jun 30, 2013 | Cruiser RV 2013 Fun Finder X X-214WSD
NO AC fault
First check your 120 volt outlet.
Then get or test your transformer, 120 volts input, 24 volts ac output.
Connect and you should be good.
Gary
Sep 18, 2011 | Orbit Sprinkler System Power Source...
I have philips hts8100 from usa , can I plug it in 220 volts or 110 volts
The Philips HTS8100 is designed to use 120 Volts AC. You could use a 220 Volt AC to 120 Volt AC Step Down transformer to power this using a 220 Volt outlet. Here is what you will need:
http://www.pcrepairshop.org/all-493964-B001TPZ294-Automatic_Transformer_Adapter_500W_110v_220v_220v_110v.html
Jul 11, 2011 | Philips HTS8100 Theater System
I live in germany (military) what is the power 120-240?
Good day!! The 120-240 power simply means the supply of your TV can be plug in to 120 Volts AC to 240 Volts AC that will come out to your outlet.For example your outlet is 120 Volts AC you can plug in your TV in there.In short your TV supply is auto-volt.
I hope this information could help you.Thank you.
Apr 17, 2011 | Proscan 24LED45QA TV
My power adapter won't work in a 117 ac volts outlet. It works in a 120 ac volt outlet. And it gets hot. Why? My Lenovo adapter works just fine in the 117 ac volt outlet.
check the amps (A) not just the volts (V) of the computer. The details (A and V) on the adapter should always be less than the details (A and V) on the laptop/notebook (see under it).
hope this helps,
kc
Feb 23, 2011 | Samsung N145-JP01US Netbook
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
B&D 400W Inverter won`t run my laptop
even the smallest inverter can run a laptop, something is wrong with this unit
Jul 25, 2009 | Black & Decker 1000w Power Inverter
Just put in a new ac unit and replaced a old one. old unit was 18000 btu and the new one is on 12,000 btu I used the same power outlet but the new ac unit starts up but then shuts down and seems like it is...
The 18,000 btu A/C is 230 volts, are you sure the 12,000 btu unit is 230 volts most are 120 volts.
Usually 12,000 btu is the biggest 120 volt A/C you can buy.
Jul 10, 2009 | Heating & Cooling
Voltage
no!   It will be ruined if you try that.
Oct 16, 2007 | Kirby G6 Bagged Upright Vacuum
Sunpentown 1000W Port Gas Generator Logo
76 people viewed this question
Top Sunpentown Electrical Supplies Experts
John Trevino
Richard Lilja
Richard Lilja
wadingriver
wadingriver
Are you a Sunpentown Electrical Supply Expert? Answer questions, earn points and help others
