Question about Canon DC20 DVD Camcorder
Changing from Low Resolution to High Resolution
Is there a way to change the resolution on my photos once I've taken the photo? The photo still resides on my Canon DC20...I have not yet downloaded photo.
  • Liquoric Jan 10, 2008
    I am aware of using other software but in enlarging it its very pixalated in fact in printing I get an error message indicating its very low res. I'm wondering if the resolution can be changed on the picture while the picture is still loaded in the camera.
    Scholar:
  • 70 Answers
To make it bigger or smaller???
Easy, use photoshop or other software for photo processing.
If you want to make it bigger, do it step by step.
Making smaller is easier. There are many free software
Posted on Jan 10, 2008
  • Anonymous Jan 11, 2008
    Some camera have software to resize.
    But the best is using Adobe Photoshop.
    You can resize (make bigger) the pixel.
    If you click menu "Image size", then you can put what size and resolution you want.
    Make sure that you choose "bicubic".
    Then, if you make much bigger, do it step by step, more steps is better.
    Adobe Photoshop gives good result. I can't say much with other software. But a good free software is Irfanview.
6ya staff
SOURCE:
Hi, I have an LG Flatron w2343T and on a recent restart the screen resolution came up all distorted in that all the icons are bigger and my wallpaper photo is enlarged to the point that I can only see...
For some reason your screen resolution changed, to adjust it
Right click on a clear area on your screen, select Properties,
select the Settings Tab, Screen Resolution, adjust to the desired
resolution
Jul 13, 2011 | LG Flatron L2320A 23" LCD Monitor
Changing Resolution On A Fuji A350 Camera
photos that have been already taken before any changes will not be affected after photo setting.Use camera menu or setup to look for RESOLUTION, PHOTO SETUP, IMAGE TYPE,STANDARD OR TYPE on menu to change photo resolution..
Dec 06, 2007 | Cameras
My screen blurry and photos stretch
Hi joganda1,
Try changing you screen resolution. You may right-click on the desktop and then click on properties/personalize and choose Settings/Display settings then drag the option low to high. The higher the resolution the better and sharper photos you will see in your screen.
Thanks,
allanhunt
Apr 22, 2011 | Computers & Internet
Canon scanner speed slow
Various ways....Try these! the slow problem wil get off
How to change the resolution (Windows)
The precision of printouts can be improved by changing scanning resolution.
The higher the scanning resolution is, the more precise the scanned images are represented, however, the file size gets larger.
The scanning resolution can be changed before scanning photos.
Note: When the scanning resolution is doubled, the image data size will be quadrupled.
When the data size is large, the throughput speed may slow down or may occupy too much of the computer's resources (memory).
<Procedures>
Memo: The following is explained using MP Navigator 3.0 procedures.
To scan using MP Navigator:
1. Launch MP Navigator and click Photos/Documents (Platen) on the Scan/Import tab.
80006642en_05sj00759_en_00.jpg- The window you see varies according to the printer model.
2. When the Photos/Documents (Platen) window is displayed, click Specify.
3. When the Scan Settings window is displayed, select the resolution in Scanning Resolution.
If necessary, set other items as well.
4. Click OK.
5. In the Photos/Documents (Platen) window, click Scan to start scanning.
6. Changing the resolution is completed.
To scan using the scanner driver:
1. Launch MP Navigator and click Open Scanner Driver on the Scan/Import tab.
80006642en_05sj00765_en_01.jpg- The window you see varies according to the printer model.
2. Change the resolution.
According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
- To set the resolution in Simple Mode:
(1) Select the Simple Mode tab.
(2) Select the output resolution from the Destination pulldown menu.
If necessary, set other items.
- To set the resolution in Advanced Mode:
(1) Select the Advanced Mode tab.
(2) In Output Resolution, select one of the preset resolution, or enter the number from 25 to 19200 to specify your favorite resolution.
3. Click Scan to start scanning.
4. Changing the resolution is completed.
Jun 01, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Blurry enlargements
I suggest altering the settings a little and if that doesn't work try using a different software to enlarge images. Such as windows photo gallery. That's not too good for enlarging just good for keeping the quality up if that isn't good enough try using a free trial of photo shop.
Hope I helped Dr Red
Apr 05, 2010 | Sanyo Xacti VPC-CG9 Digital Camera
The photos on the frame aapear
You may have to change the screen resolution on the frame if it can be changed. Some frames do not allow a change in this way. If you cannot change the resolution then try changing the size and resolution of the photo's on your camera. You may have to change things several times until you find the best fit. Refer to the manual for the frame on how to change the frames display size and resolution..
Apr 02, 2010 | Microsoft Windows XP Professional
I can't upload photos on to e-bay - I think it's because they're too big. How do I change settings on my camera to reduce the size of the photos taken? The longest side needs to be between 1000 - 1600...
This will be difficult as you didn't mention the camera make or model. But assuming Canon, press Function, Func, or Func/Set, then scroll down to the bottom selection.
Select the "S" for small picture resolution (this should be around 640 x 480). When you want to go back to high resolution, just reverse the process and select "L" for Large (High) resolution pictures.
Nov 07, 2009 | Cameras
Minolta Dimage S414 Problem with resulution
What you are seeing is the difference between "pixel count resolution" and "embedded resolution". So in your example 2272*1704 is the actual pixel count resolution as recorded by the camera & 72 is the embedded resolution that tells the software (in this case photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it to 300 for printing. You can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions". This is a complex subject, I recommend looking at the following web page: http://www.fotofinish.com/resources/centers/photo/resolution.htm
Aug 08, 2007 | Konica Minolta DiMAGE S414 Digital Camera
Canon DC20 DVD Camcorder Logo
2,061 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
