Question about Ovens
Temperature problems in Bosch range
I have a Bosch range HDS 255U dual fuel. The convection bake mode will not heat up properly and maintain the desired set temperature, it continues to stay on preheat and never gets to the right temperature. I saw a possible service bulletin for part # 445-300.
I would check to make sure you are using a 220 plug.
Posted on Mar 19, 2008
Oven on lock. How do you unlock
most likely the door locked due to an overheat situation. It's a safety feature on most ovens made today. It may be caused by a fan motor not running properly thus allowing area above oven cavity to sense extreme temperature, blockage in air flow pattern, or a bad temperature control.
Whatever the cause, it's best to have a tech take care of this issue for you to prevent danger to you and your family.
Jan 29, 2015 | Kenmore Elite Stainless Steel 40" Dual...
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
Kenmore oven take a long time to heat up, but bakes just fine once it reaches temperature. Is there anything I can do to speed up the heating process?
Start earlier?
>> check all elements for current,
check seals
check temperature calibration (allowed to be 15% ie 180 can be 153 or 207 Celsius!) no wonder Margs' scones cook faster at her house :-)
Oct 15, 2013 | Kenmore Elite Stainless Steel 40" Dual...
Oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Dec 14, 2008 | Ovens
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    Bosch HBN 642 -- single oven cycles and doesn't get above 325
    WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
    If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
    May 28, 2008 | Ovens
    Amana Convection oven not controlling temp
    I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
    Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
    No heat
    relay in the control circuit maybe bad
    Aug 23, 2007 | Bosch HBL 5056 Electric Double Oven
    Oven doesn't maintain temperature
    When an oven doesn't maintain the set temperature, first make sure no one is allowing the heat to escape by opening its door. If not, the oven control either needs to be re-calibrated or replaced. To have the control replaced, call an appliance service person.
    Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
    Ovens Logo
    225 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
