Question about Dell (6F858) Cooling Fan
MY DELL HAS A DATECH COOLING FAN, AND THE COMPUTER KEEPS SHUTTING OFF DUE TO FAN FAILURE, WHAT REPLACEMENT FAN CAN I INSTALL TO FIX THIS PROBLEM
  • Dell Master
  • 2,072 Answers
Goto this link
Dell parts
http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&l=en&cs=19&s=dhs&~ck=anavml
Select your computer model and you can order the exact fan
Leave comments if you need more help
Posted on Nov 22, 2009
Orange light keeps blinking on my dell poeredge 2600
Orange blinking light means a component failure.
I had a cooling fan failure and this caused the orange light. When there is a failed fan the other fans RPM is increased to compensate. Is the server fan noise excessive?
Aug 21, 2013 | Dell PowerEdge 2600 Server
Dell Dimension 2400 Keeps Shutting Off
its smps problem...if u want clean ur cpu read ur dell guider ....
Jul 24, 2012 | Dell Dimension 2400 PC Desktop
My samsung r60plus laptop keeps overheating and shutting down.how can i fix this
This problem is caused by a faulty cooling system. The fan is probably faulty and or the heat-sink assembly is clogged with dust.
Failure to correct this problem will cause the CPU to fail.
Check the fan to see if it spins freely, if not replace the fan. Also check the heat-sink assembly/fan and remove the dust clogging these components.
If this does not fix the problem and the laptop has vents on the bottom of the laptop, then you can purchase a fan assisted cooling pad. Place the laptop on this pad and this will provide addition cooling to the laptop.
Feb 08, 2010 | Samsung Computers & Internet
I changed the CPU fan on Dell dimension 3000 but it does not run.
Dell uses a proprietary fan on it's cpu's. This is more than likely your problem. The motherboard does not recognize the new fan and the motherboard is not powering it on. Without replacing the motherboard you are stuck using dell replacement parts for this model. The motherboard & psu are also proprietary in this model so it would take a whole lot of modification to use anything but Dell replacement parts. Your pc is shutting down due to overheating. Sorry. Hope this helps.
Jul 12, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 4600 Cpu Fan replacement help
I know that there are many of these types of system boards out there, What I would do is contact Tiger Direct either in Canada at www.tigerdirect.ca or in the US at www.tigerdirect.com and send the sales team an email sales@tiger.com - They will usually find anything that you need and have very quick and reasonable shipping rates.
Give that a try and see if it works for you.
May 26, 2009 | Dell Dimension 4600 PC Desktop
Cooling fan Dell Dimension 3000
That is the correct way. It is a newer design that keeps the hot air from the CPU heatsink out of the case. 35C is a good temp.
Sep 23, 2008 | Dell (6F858) Cooling Fan
Dell Inspiron 8600 - overheating and shutting down
Start by cleaning the fan and heat sink. Dirt or dust build up can cause them not to work as efficiently as they should. If cleaning doesn't fix it, you might consider replacing the fan and heat sink or purchasing a cooling pad.
Jul 22, 2008 | Computers & Internet
Fan Malfunction??
Sounds like a heat issue, pop the side of your case open and turn on the PC, are there fans not moving? Take a close look at your processor fan if there is one.
Jul 10, 2008 | Dell Dimension B110 PC Desktop
Dell (6F858) Cooling Fan Logo
300 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
