Question about Poulan "Poulan" Push Mower
My Poulan ush Mower is only 3 months old and is leaking Gas. I have tried to find the leak but have had no success yet.
  • 109 Answers
SOURCE: poulan 21
Try putting a SMALL amount of gas in the carb and see if it will start, if it does, it is a fuel problem, if it does not it is probably an electrical one
Posted on Apr 26, 2009
panilling9
  • 284 Answers
SOURCE: I just bought a Poulan Pro lawn mower and after
if its new take it back tell them you want one that doesnt leak
be sure it is not overfull of oil
if you dont want to take it back replace the crankshaft seal
Posted on Jul 05, 2009
Dolfoff
  • 148 Answers
SOURCE: Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
Posted on Oct 05, 2009
RonInFla
  • 86 Answers
SOURCE: My Poulan self propelled lawn mower model
where is the oil on under there ??if it's on the shaft where the blade attaches the the oil seal is bad...that's caused by old oil, which is too thin and seeps out...try changing the oil first...
this will help...copy & paste...
http://www.youtube.com/watch?v=XXvsdWbW5D8
Posted on Apr 18, 2010
Knucklebstr
  • 222 Answers
SOURCE: I just purchased a poulan lawn mower at Kents.
You do not mix gas in a 4 cycle engine. You have to mix gas and oil for a 2 cycle engine, such as in a weed whacker, chainsaw, or leaf blower. I do not know of any 2 cycle Poulan mowers (or any other brands for that matter). Unleaded gas is all you can buy in the United States and all current mowers will run on it, although they really don't like that new ethanol additive. If your mower is new then it should have come with an owner's manual which will explain what to do, as well. Hope this answers your question.
James
Posted on May 27, 2011
How do you repair a Bolens push mower that's leaking gas out of the carborator?
You will need to rebuild the carb sounds like the float is sticking and allowing the gas to keep flowing. The needle vale is probably sticking. Check around the carb first to be sure it not coming from the line that feeds the carb before taking it off.
May 31, 2014 | Poulan "Poulan" Push Mower
Gas leak poulan pro riding mower
sounds like the needle and seat failed remove the carb and replace them the fuel we now have kills the rubber on them
Apr 08, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a Poulan 450 push lawnmower, and it's only a month old, and I've only used it once before to cut my yard. It worked perfectly, and now three weeks later I added gas to the mower, and the oil level...
Remove spark plug,it may be fouled and have gas on it,clean it and then reinstall and try if that doesn't work,try a new one.Also check the air filter,may need cleaned or replaced.
Jul 09, 2017 | Poulan "" Push Mower
Poulan weedeater 12.5 drive belt diagram and part number
I have a older poulan weed eater riding mower and have a fuel problem such as gas leaking from the side of the engine from a small hose approx.2inch which curves. can some one assist me.
Apr 30, 2010 | Poulan Genuine Weedeater Part # 36006-128
My Poulan self propelled lawn mower model 961320048 is leaking oil from the bottom after use. I cannot find the oil drain plug to tighten it. Where is it located?
Apr 18, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Craftsman 29cc 4 cycle weed eater. Cranks but will only idle. Seems to bog out. Will only run in full choke at idle. Have changed gas and checked lines for leaks or stoppages. None found. Can not...
remove the sediment bowl on the bottom of the carb,but dont lose the gasket and watch out when the float drops so the needle and spring in the bore dont fall and you lose them,then clean out any dirt in the bowl and in the needle seat andget some carb cleaner and throughly clean out all openings in the carb,its a california carb thats why there are no adjustments
Mar 13, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan Pro lawnmower (Briggs and Stratton 128 cc engine) will start when primed but will not stay running. New Lawnmovewr, < 3 months since purchased at Walmart
IF IT IS A BRIGG & STRATTON ENGINE YOU CAN GO ONLINE TO BRIGGS & STRATTON.COM AND ASK THEIR TECH SECTION ABOUT THE PROBLEM. FOR 3 MONTHS OLD SOUNDS LIKE DIRT OR WATER MAY HAVE GOTTEN INTO THE TANK. WHEN YOU PRIME THE MOWER YOU ARE FORCING GAS INTO THE CARB AND ENGINE AFTER THAT THE ENGINE SHOULD PULL THE GAS IN THE ENGINE, I WOULD SAY THE CARB MITE NEED REBUILDING BUT NOT AT 3 MONTHS
Sep 17, 2009 | Poulan Garden
Poulan "Poulan" Push Mower Logo
47 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
