Question about Cnet CWR-854 Router
Can't configure my router to my modem, i follwed the instruction already from the manual. it still didn't work. still can't connect to the internet
  • Tim Hunt
    Tim Hunt May 11, 2010
    what is your modem cable dsl ? and who is your provider
  • 2,263 Answers
Router set up is very easy. You will need to access the router set up interface to make changes on the router.
If you are not able to go online using the router then you will need to check the settings of the router.
First make sure that your computer is able to go online when connected directly to the modem without the router.
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.ind network key.
Router set up for Cable Internet service provider :
This connection type uses the MAC address of the main computer to identify your connection. They generally register the MAC address of the main computer. So the MAC address is everything in this connection type. Now we set up router using the MAC address of the main computer. Main computer is the computer which was able to go online through the modem. Use only the main computer to set uo the router.
Connect the modem and the computer to the router . Check the IP address on the computer.
According to the Default gateway value open the set up interface of the router. Once you open the set up interface, you will need to clone the MAC address of the computer. Then change the wireless settings on the router and your router is ready to go.
Router set up for DSL Internet service provider.
What is DSL connection?
DSL (Digital Subscriber Line) is a high-speed Internet service that competes with cable Internet to provide online access to local customers. DSL operates over standard copper telephone lines like dial-up service, but is many times faster than dial-up. In addition to being faster than dial-up, DSL does not tie up the phone line. Coexisting with telephone service in this way allows users to surf the Net and use the phone at the same time.
There are two types of DSL connection
1 ) PPPOE : In this connection type you will get user name and password from the Internet service provider. Your computer will not be able to go online when connected to the modem only. You can open the router set up and change the Internet connection type to pppoe and type the user name and password for the ISP. After that change the wireless settings of the router and it will be ready to go.
2) DHCP : In this connection type your computer will be able to go online when you connect it directly to the modem.
you don't require the user anme and password for the ISP.
In this connection your computer will get a private IP address from the router. According to this the IP address of your router will change. Change the wireless settings of the router and it will be ready to go online.
Click Here for more info
Posted on Dec 04, 2009
My router wont work when it is connected to the modem. the message that on there says limited access
If you already verified that your modem works if computer connected directly to it, try powering down router and modem. Start modem first and wait at least 2 minutes before starting router.
if this doesn't help you will need to verify that your wired connection to router works first before you can attempt to use wireless.
With your computer connected to the router try to open router setup page. Based on router type you should be able to access it from browser using: http://192.168.1.1 or http://192.168.0.1 you will need to login using default admin/admin account or according to router user manual. Configuration page will allow you to verify if you have Internet connection and configure other settings including wireless connection.
Mar 15, 2011 | Computers & Internet
Wireless is nonexistant
You need to bridge mode your modem. And when set it to bridge mode already. Connect the dlink router. Access the gui of the router. Enter there your username and password. Powercycle modem, router and computer. Check connections. I f this didnt work, set again your modem to default, connect your router. Configure your router with username and password. Powercycle again. Check if it is working.
Jul 16, 2010 | D-Link DI-524 4 Port Wireless-G Router -...
No internet connection as claimed after follwing instruction
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Mar 06, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Hi, i have wnr2000 and am trying to set it up. i'm at the setup wizard which says that i already have a valid internet connection. what does this mean and what do i do next?
Basically you need to sign up with an Internet Service Provider in your area. The ISP will advise you the type in modem/Internet connection you need for their service (ie. DSL or cable) and advise you or provide you with a compatible DSL or cable modem. The ISP will provide an installation disc or instructions to configure the modem so it connects with their Internet server.
The modem is then connected to the wnr2000 router's Internet/WAN port with a LAN cable.
If you have already configured the modem and connected it to the wrn2000 router and the setup wizard has detected that you already have a valid Internet connection (it has detected your TCP/IP address which your Internet Service Provider has given you - this IP address is your unique network address - it is similar to your house address in your street, in your suburb, in your state, and in your country). Just click OK and continue with the setup.
Oct 30, 2009 | NetGear WNR2000 Wireless Router
How to configure 4 port router
If you just purchased and opened the box-
1- open your package and take out the instructions on what do to for setting up (not the manual)
2- connect your modem (source of internet) to the internet port of your router with the cable provided by your router packaging.
3- with the other available cable (that you already had) connect to one of the 4 ports (prefferably port #1) and the other end to your PC/Mac
4- If everything was powered on already during the connection of all these cables, you can to unplug the power to the internet modem (source of internet connection) and your router now.
5- Plug in the Internet Modem power to the wall and wait 30-45 seconds... then plug the power to the router and wait another 30 seconds.
6- now, try to go on the internet with your computer.
7- if it still doesn't work, just restart your computer 1 time
8- If it still doesn't work after you restarted your computer (very important to do this 1 time after following abpve steps), check the router's instructions for troubleshooting tips and follow up post us where you're stuck and provide to us:
What model router you're using, PC model and which Windows/Mac Operating system you're using. :)
Please rate us. :)
Jul 19, 2009 | Edimax 4 Port Wireless AP Broadband Router...
Cant connect to the internet with linksys wrt160nv2
if this is DSL connection then you have to configure your modem before you connect router
follow this
first disabled wireless on your modem/router
.1) Turn off DHCP on your modem/router I am assuming this is verizon westell
2. Configure the first VC port to Bridge-Bridge mode
3. Keep hitting "apply" in the windows until the 7500 reboots
4. Plug the "Internet" port on the linksys to one of the normal ethernet ports on the modem /router
5. Turn on the Netgear and wait for the green Internet light to go solid
good luck if this does not work provide more info on your setup
Jun 12, 2009 | Linksys WRT160N Wireless Router
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Unable to connect a WGR614 Wireless Router to a DM111P Modem
Sounds like you need to port forward your router. Go to port forward .com. find your router and follow the instructions. Hope this does the trick for you.
Nov 26, 2008 | NetGear WGR614 Wireless Router
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Dificulty in configuring wrtg4g
There are three major steps to setting up a wireless router.
First set up WAN side access to the internet. For this you need information about your internet service provider. Please respond with your internet service provider's name or better yet a link to their help/support website.
I assume you already have access to configure the router at 192.168.1.1 if not please do the following. Open Internet explorer and enter 192.168.1.1 where you would enter fixya.com and press enter -- do web pages appear in your screen from the wired computer. If so we have manual access to configure the router. If not let me know.
Please reply with a response to this message.
Second we will test wireless connections to the router
Third we will secure the tested wireless connections to the router.
This process will require interaction and several iterations of instructions to complete. Please add a comment to this request with the necessary information if you with to proceed in this fashion.
Jan 01, 2008 | Linksys Wireless-G WRT54G Router
Cnet CWR-854 Router Logo
303 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
ddalecki
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
