F10 error is: Runaway Temperature
what you can do:
1. (F10 only) Check *RTD
Sensor Probe & replace if necessary. If oven is overheating,
disconnect power. If oven continues to overheat when the power is
reapplied, replace EOC. Severe overheating may require the entire oven
to be replaced should damage be extensive.
*RTD
SCALE
Temperature
(�F)
Resistance
(ohms)
32 � 1.9
1000 � 4.0
75 � 2.5
1091 � 5.3
250 � 4.4
1453 � 8.9
350 � 5.4
1654 � 10.8
450 � 6.9
1852 � 13.5
550 � 8.2
2047 � 15.8
650 � 9.6
2237 � 18.5
900 � 13.6
2697 � 24.4
hope the chart dont get jumpled if it does go to
http://www.applianceaid.com/faultcodes3.html
please rate this and check fixya if it has answered what the f10 error is. for safety reasons I wouldn't use it if it tends to keep getting way over heated until you have replaced what I said above or have had it serviced.
Good Morning mark, thank you for your post!
Based off the information you have provided your Frigidaire range is displaying an error code of "F10". An "F10" error code normally stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to experience an issue with the "F10" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. This will help you avoid any unnecessary part purchases. Hopefully this information has been helpful. -Matt
