Question about Kodak Easyshare C813 Digital Camera
I replaced the batteries and it won't turn on
    Genius:
  • Kodak Master
  • 1,099 Answers
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 16, 2009
My 1997 Suzuki Bandit600 won't start, the battery
during the battery replacement did you manage to either forget or damage a wire that powers up say your ignition module... ?
Sep 15, 2014 | 1997 Suzuki GSF 600 S Bandit
I have a 95 honda civic ex,wont start.ran fine yesterday,wont start this morning.battery is fully charged,new cap and rotor.would do u think might b my problem
if it wont turn over 1st check the ground s on the car and the battery 1st. your battery can be fully charged and the car will not start even over night this can happen. then look at the starter. Note: if you have over 109K on the car and the timing belt has never been replaced you will need to have this checked as well.
Aug 16, 2014 | Cars & Trucks
My 1991 Ford Tempo won't start. It turns over but doesn't spark. The battery has been replace, checked fuel pump and spark plugs but it still won't turn on. Help?
change the ignition pick up coil assembly normally located on the distributor under the rotor on the bottom of the distributor or just replace the distributor
Jan 30, 2013 | 1991 Ford Tempo 4 Door
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Battery won't Charge
Hope this helps
Nov 04, 2012 | HP Computers & Internet
2004 buick rendezvous sometimes won't start. clicks but won't turn over. replaced starter, battery, and ignition switch. what now??
We just went through this with our 2003 Rendevous. Clicking like crazy but wouldn't start. Replaced the starter but still doing the same thing. Our next step was going to be replace the battery (which tested well) and the ignition assembly. Out of frustration, I hit the top of the hood and the headlights came on!! Further investigaton proved that the problem was a corroded ground wire on the battery. Hope this helps
Aug 06, 2012 | 2004 Buick Rendezvous
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
1995 geo tracker won't start. I've replaced everything except the ignition switch. It used to click when i turn the key, now it won't even click.
DISCONNECT YOUR BATTERY AND RECONNECT, THIS SHOULD RESET THE BRAIN.
ALSO...WHEN YOU TURN THE KEY, LISTEN TO HEAR IF YOU CAN HEAR THE FUEL PUMP COME ON...IF NOT, GUESS WHAT? HOPEFULLY NOT!... BUT,YOU MAY NEED TO REPLACE THE FUEL PUMP, IF YOU CAN'T HEAR IT WHEN YOU TURN THE KEY, AFTER YOU'VE RESET THE BATTERY!
HOPE THIS HELPS!
Aug 30, 2011 | Geo Tracker Cars & Trucks
My Volvo s60 won't start replaced battery and starter and still won't start battery test fine what can I do I have good power throught out
you will need to try to turn the engine manually to make sure its not frooze. if it turns then you might need to check the starter again.
Aug 28, 2011 | 2001 Volvo S60
95 jeep wrangler 4.0,won,t start,dash lites won,t go on.replaced starter relay.still won,t turn over.
Try checking the battery and battery leads. Sounds as though you have a bad battery. Also check your fuses under the hood and dash.
Jun 03, 2011 | 1995 Jeep Wrangler
Kodak Easyshare C813 Digital Camera Logo
61 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
