Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Heat will not come on.
The heat will not come on. Checked the fuse and replaced batteries - the air and fan work. I have white-rodgers 9910S - don't know if this has any bearing but we just returned from 10 days away.
  • 99 Answers
No heat troubleshooting
Diagnostic: Set SYSTEM Switch to HEAT and raise the setpoint above room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation listed above. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a HVAC service
person to verify the heating is operating correctly.
If you need further support call the techline 18002842925.
Posted on Apr 07, 2010
White-rodgers 1f80-261 thermostat: Set to heat, "flame icon" appears but no heat and no fan. Thermo doesn't click when adjusting temperature. Set to fan,there is no fan.?
There is a 3 amp fuse in the main circuit board. If this fuse is bad ,nothing will work but because of the batteries in the thermostat it will lead you to believe that the unit is working properly,however, it is only showing you what is supposed to be. Replace the fuse and everything will work.
Oct 17, 2015 | Thermostats White Rodgers 1F80-261...
I don't want to program the 1f85-275 thermostat, i will adjust when needed
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. To manually operate the unit just set the thermostat to heat mode and the fan to auto. Press the hold button one time then set you desired temperature.
Nov 15, 2012 | White Rodgers White-Rodgers 1F85RF-275...
White rodgers customer service phone number
we are not white rodgers /emerson --the following links can assist you but if the trooble shooting doesnt fix problem just replace the stat
White Rodgers White Rodgers White Rodgers Thermostats Thermostat AC Wholesalers How to Troubleshoot White Rodgers Thermostat eHow
May 30, 2017 | Heating & Cooling
I also have a white rodgers 1F80-24 thermostat that all of a sudden the numbers on the display are all broken up. I have changed the batteries.........no luck. I have looked for the exact replacement,...
White Rodgers 1f80 24 - Compare Prices, Reviews and Buy at Nextag ...
Im not sure what your application is but this stat is for a heat heat pump operation or forced air with A/C and heating. If you don't need the heat pump operation and you are using forced air furnace make sure all connections are good as labelled and connected to the proper terminals at both the furnace and thermostat If you installed new batteries and programmed the system without connecting to the sub-base and the numbers are still broken up you should replace it. I have attached a link for you to follow and you can see multiple types of White Rogers on the site home page
Jun 08, 2011 | Heating & Cooling
I am replacing a White-Rodgers thermostat with a Hunter 44155C and dont know where to connect the wires. I have white, red, green, blue, and yellow wires and none are labeled as to what they are.
The Yellow wire is for cooling, the white is for heating, the red is for power, the green is for blower fan, the blue is your common wire, all you should have to do is color code the wires to the thermostat. The thermostat should have the colors labeled R,W1,G,Y,B or C for common if it's wired correctly at the Air Handler or evaporator. The blue wire should go to B, or C.
May 28, 2011 | Hunter Fan Company 5/1/1 Programmable...
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
On my white rodgers thermostat 1F80-361 air and heat wont work
Mine is doing the same thing!! My daughter and I are FREEZING!!!
May 23, 2010 | Heating & Cooling
Thermostat
What were each wire connected to on the white rodgers? The connectors on the white rodgers should have markings. Tell me this and I can tell you how to wire your new stat. This hunter will not work with multi stage heat pumps..so I need to know what was connected to what on the white rodgers to know what type of unit. Thanks Kevin
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
376 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
