Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
I also a Paloma tankless water heater that is 2 years old. I am now getting an error code C7 76 also. Is this something I can take care of, or should I call a plumber to address?
  • 244 Answers
Remove power source from the unit. If remote control is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support .
If this helps, please indicate so.
Mike//jzklipper
Posted on Nov 17, 2009
I have a Paloma PTG-74PVN-1 high volume tankless water heater installed in 2007. Recently, I am having hot water temperature problem, no error code is displayed, but it can not heat the hot water beyoun...
Even though you are not getting an error code, there are may be some diagnostics in the controller that can identify whether it's an electronic (controller/sensor) or a heat exchanger issue. I would contact Rheem tier-2 support.
Jul 01, 2014 | Rheem Paloma Tankless Water Heaters...
I have a paloma tankles water heater model #ptg-42pvn i am getting an intermitent error code C4,12. what is the problem?
Copy following link for Rheem-Paloma tankless troubleshoot and error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
If unit worked before: Maybe bad PC board. Maybe lack of required yearly maintenance.
Common error codes can be caused by not following maintenance protocol such as cleaning combustion parts, checking gas pressure, checking venting, and air intake, bleeding gas line etc.
Too bad Rheem-Paloma manuals do not show HOW to conduct this maintenance, leaving customer with many unknowns, and no way to oversee that maintenance performed by hired technician is complete, and matches recommended maintenance.
Sell unit on ebay, and install tank-type gas water heater.
Mar 20, 2013 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Paloma tankless water heater model no PTG-74XP-2 error code c8
In several cases i have had to change the pcb board.... code 76 is no communication between remote thermostat and pcb..... this is a problem the first generation rheems seem to be having.... contact rheem if under warranty you will need to get pcb and program chip sent to you. Really need a experienced tech to install board and program it for you...... hope this helps...
Jan 25, 2012 | Rheem Paloma Tankless Water Heaters...
Error 13 paloma tankless hot water system. no hot water
Before calling service technician, open following links for error codes, Rheem/Paloma chat and tech support, and possible manual:
http://www.fixya.com/support/t3444443-paloma_tank_less_water_heater_flashes
Error codes are considered start-point for troubleshooting.
Tankless manuals recommend yearly service including burner cleaning, gas pressure and plumbing check, de-liming etc to prevent problems and so technician is familiar with that specific unit.
Aug 05, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Getting a 76 flashing on my Paloma PTG-74XP tankless water heater
Error code 76
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/pdf/Rheem-Tankless-Fault-codes.pdf
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 30, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
I keep getting a C2 11 error code. Unit lights and immediatly goes out showing that error. At other times it operates fine. The problem seems to be occurring more frequently. It has been in service...
that error code means not enough gas.
however, there might be something going on with your venting. it could be sucking exhaust air back into the unit. this will cause the same error code.
if your problem is intermittent, then I would suspect the venting to be the issue.
Aug 22, 2010 | Rheem Paloma Tankless Water Heaters...
Paloma tankless ptg42 water heater error code c4/13
4 error message, the 4th (last) error code is #13, not enough oxygen.
Check the location of the heater, if it is fine the ODS sensor (actually is a thermal couple) is bad.
Dec 25, 2009 | Rheem Paloma Tankless Water Heaters...
Paloma tank less water heater flashes code C4 13 and we have no hot water?how to fix it?
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Nov 16, 2009 | Rheem Paloma Tankless Water Heaters...
Richman gas lp tankless hot water heater. used for infloor heat and kitchen and bathroom hot water. getting c2 and 11 error code. water temp. setting 120. ran great last year. made no changes. we have very...
I had the same problem with my Paloma a year and a half after installation...contacted Rheem\Paloma\Richman customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Nov 09, 2009 | Rheem Tankless Hot Water Heater...
I have a paloma tankless water heater about 3 years old model PTG-74PVN and it works for 2 minutes and shuts off with error code C4 and 13 flashing. (City water pressure is fine)Can anyone help? Thanks...
Nov 03, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
528 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
