Question about Delta Plumbing
I need to replace the two o-rings and the bushing for the spout of a Delta 2467 series. How do I get the spout out?
  • 21 Answers
The spout is locked in place with a nut. Loosen the nut, raise it above the spout post, and the spout itself will simply lift up towards the ceiling.
Posted on Nov 16, 2009
I am trying to replace an old delta monitor 1300 diverter spout. It seems when I take off the spout it has a threaded part in the middle of copper pipe . The spout itself has a plasticinsert with threads....
Tub spouts are pretty much interchangeable although you may find the replacement spout cannot be installed easily because the threaded copper stub does not extend far enough to engage the threads inside the spout.
Nov 28, 2013 | Delta Faucet Delta T13422 13 Series...
Delta faucet #467-DST. The last couple of weeks my kitchen faucet doesn.t want to turn back and forth easily. I thought it might be a kink in the sprayer hose. Help
There are two rubber o rings under the spout, one at the top and one on the bottom, Remove the handle then the nut that you will see that is in contact with the spout. Rock the spout left to right and pull up at the same time. You then can replace the O rings and make sure you put some food grade lub on the O rings. Replace all that you took off and you are god to go.
best of luck Rich
Sep 05, 2011 | Delta Faucet Delta 467-SSSD-DST Palo...
How do I turn the shower on? I just moved into a place that has a Delta series 1400 Monitor shower handle, a smooth faucet, and NO mechanism whatsoever that I can see for switching from bath to shower. Is...
There should be a dirverter on the tub spout. It will be either a knob to pull up or a ring to pull down on and hold untill the water comes out the shower head.
If there is no dirverter go buy a new tub spout with one.. The prior owners may have installed the wrong spout.
Apr 01, 2011 | Delta & Single Handle Shower Faucet
I have a Delta shower assembly with a pull-down diverter. When I engage the diverter for the shower, half the water seems to make up to the shower and the other half is forced through the back of the...
One of 2 things is happening. Either the o-ring is shot, or you have a hairline fracture of the plastic around the brass adapter. The o-ring is a #18, but if there's a crack in the plastic you'll need to replace the spout.
Oct 03, 2010 | Delta Faucet Delta RP17453 Pull-Down...
Hard to turn spout side to side
Remove the spout and apply a thin coating of plumber's waterproof silicone lubricant to the O-rings on the spouts mounting post. If the spout is still difficult to turn, replace the O-rings. Here is the link to the delta waterfall parts breakdown.
Sep 04, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
How do i remove the spout to replace o rings on 174 spout?
1. you can pull the spout while turining it. If this still does not work, then spray wd40 at the base and try again. Last resort, deep the spout and base unit in 50/50 solution of white vinegar for a day and then try to take it apart.
The base and spout are snugged fit so you will need to apply some pressure to move it.
Mar 21, 2010 | Delta Faucet Delta 174-SSWF Waterfall...
I have a Delta Waterfall 172 SSWF faucet in my kitchen. I need to replace the water spout - I have the replacement spout. It appears there is a plastic retainer ring that holds the spout in place but I'm...
Normally you just turn that ring, counter clockwise. If too hard to turn, I usually put a rag over it, to avoid scratching, and use a pair of channel lock pliers, and squeeze just hard enough not to slip.
Jan 15, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
Water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Nov 25, 2008 | Delta Faucet Delta 172-SSWF Waterfall...
Plumbing Logo
617 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
