Question about Microsoft Windows XP Professional
Parse error: syntax error, unexpected '<' in /home/nicoc/public_html/file.php on line 15
    Brigadier General:
  • 10,406 Answers
Contact the owner of the 'nicoc' account on the web-site.
The 'file.php' page, written in the PHP scripting-language, has a "bug" in the programming.
Posted on Nov 17, 2009
How do I fix this Parse error: syntax error, unexpected &#39;.&#39;, expecting &#39;)&#39; in /home1/ragtop23/public_html/wp-content/themes/twentyten/comments.php on line 78?
Change to another theme.
Delete the twentyten theme
download and install twentyten again. Done...
next time save a backup of the file before you start editing it.
Dec 20, 2014 | wordpress.org
I built a website using wordpress and i changed a lot of Theme in a very short period of time... then i was redirected to this page .. what should i do? Parse error: syntax error, unexpected T_FUNCTION...
This sounds like a problem with one of the theme files. Do you have a fresh copy of the theme files? There are a few ways you can fix this. One, you can change to a default theme or you can replace the current theme files with fresh copies.
1 to change the theme to a default theme such as twentyeleven, you will need access to your database using PHPMyAdmin. That is in your cPanel. It is in the Database section. You will need to know which database to work with.
1. Choose the database from the dropdown box on the left side of the page..
2. Find the wp_options table and click it.
3. On the main screen (right side of the page find the > link and go to page 2. Then find these rows: 44 and 45.
4. Edit them by clicking on edit and change the Option Value box to the defualt theme. Usually it is twentyeleven, twentytwelve, or twentythirteen. Change both rows and save by clicking go.
Sep 26, 2013 | Apple MacBook Air
when are you gettting this error message ?????
Cannot view my own website. it reads: "Parse error: syntax error, unexpected $end..." in my index.php file. HELP
Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Locate the syntax error manually. Step through each section of your code. Most code will be sectioned off into groups or functions. Carefully proof your code. Be sure to pay close attention to how lines are grouped. A common syntax mistake is incorrect grouping.
For instance, if you have an If Else statement embedded in another If Else statement, be sure the embedded statement is surrounded by a separate set of parenthesis or brackets, depending on your language. Double-check notes sections. Notes are only for the developer to see. However, if the syntax isn't correct, the notes may become part of your application, which may not agree with existing code. Ensure the syntax around your notes is correct. Run a debugger if possible. This will make locating errors much easier. A debugger will be found under a menu such as Debug, Run or Tools or as part of your SDK's toolbar. Allow the debugger to run. Errors will be listed at the bottom or right side of your screen. Many debuggers will highlight possible errors in your code as well. A line number, along with the possible error, will be listed in the error message. Locate your syntax error if the debugger isn't correct. Sometimes a debugger will show you where your application stopped working correctly. The syntax error itself may be above or below the line listed in the debugger message. Check all syntax within the surrounding area, especially within the line's function. Run your application after correcting the syntax error. Check every possible function of your application to ensure it works correctly. If you find a problem, double-check the syntax in your code that surrounds the problem area. For instance, if your application has a log-in screen that isn't accepting passwords correctly, check the code for the log-in screen. Remove Syntax Error syntax error typically occurs when the Web page you are loading causes a script error in the browser. This is caused by incorrect code that displays an error message or results in a Web page that does not load correctly. You can remove a syntax error by making a change to the settings of your Web browser. Common Web browsers that can experience this type of error include Internet Explorer, Mozilla Firefox and Safari.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect.
b>
b>
Apr 06, 2013 | Computers & Internet
Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING, expecting ')' in /var/www/proxy/.release/.core/proxy_s.php on line 367
Connect to the local server using Windows Authentication and specify
the AdventureWorks database as the database in use. To connect using
SQL Server Authentication, set values for the "UID" and "PWD"
attributes in the $connectionInfo parameter. For example:
$connectionInfo = array("UID" => $uid, "PWD" => $pwd));
$uid = "Administrator";
$pwd = "Password1";
$pwd = "Password1";
$serverName = "(localhost)";
$connectionInfo = array( "Database"=>"dbase");
$conn = sqlsrv_connect( $serverName, $connectionInfo); if( $conn )
echo "Connection established.\n";
else
echo "Connection could not be established.\n";
die( print_r( sqlsrv_errors(), true));
// Perform operations with connection.
/* Close the connection. */
sqlsrv_close( $conn);
May 09, 2011 | Computers & Internet
Parse error
A parse error is an mistake in a line of code, there is a missing charactor in the syntax of the code, ie a missing ( " ). You will need a registry repair program to correct the error try this free program from this site just copy and paste it to your text window in your browser :
http://www.snapfiles.com/get/winregrepair.html
Jan 28, 2010 | Acer Aspire One PC Notebook
I keep getting error for line 15
There's too much apostrophes in define('EMAIL_SUBJECT', ... Is this line 15?
Change it to define('EMAIL_SUBJECT', "Enquiry from 'MMSWEETS'");
Oct 17, 2009 | The PHP Group PHP
Parse error: syntax error, unexpected T_STRING in /home/a4491082/public_html/savefile_php/config.php on line 4
T_STRING is a string error. It usually means one of two things.
1. The string is formatted incorrectly. In your case check on line 4. Make sure if you have a ' that you close it with a '. Same with ". Close all " with another " somewhere. Make sure line 4 ends wth semi-colon ;
2. Usually this is the case. The line above the string it states doesn't have a semi-colon to complete the statement. In your case, check that line 3 ends with a ;
That is why it says unexpected T_STRING which means "unexpected string". The string on line 4 is unexpected because line 3 wasn't closed properly.
Aug 26, 2008 | Computers & Internet
Syntax error
go to this site and look under "error codes"
go to computer and system error codes
http://checkitright.spruz.net//main.asp?page=dp&dis=834222
Feb 07, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
91 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
