Question about Kenmore 33464 / 33465 / 33469 Gas Single Oven
Locked oven I cannot open my oven. It has remained locked as if it were in cleaning mode. What do I do?
    President:
  • 1,314 Answers
Is there a display on the clock and were you cleaning it when this happened
Posted on Jan 09, 2008
4 Suggested Answers
  • 35 Answers
SOURCE: Oven door locked
you would have to remove oven.remove top panel and disengage latch assembly if you are a tech.
Posted on Jun 25, 2007
mark_37388
  • 100 Answers
SOURCE: Door locked after cancelling self clean option
Try pressing and holding down the child lock button the locklight should go out and the door unlock on some frigidaires the clid lock out locks the door to
Posted on Mar 29, 2009
SOURCE: Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Posted on Sep 22, 2008
I used the clean oven button for the first time. After an hour I turned it off. Now my oven remains in the locked position. Help
Give it a little time. Until the oven cools the door will remain locked. You will have to manually move the latch when it cools
See the link:
  • It will not unlock until time has elapsed. It locks for your safety during the high temperature cleaning mode. Some will stay locked for the entire time even if you cancel. Some will unlock when the "brain" is sure the oven is still cool.
https://answers.yahoo.com/question/index?qid=20080802165722AAIChO4
Dec 11, 2015 | Ovens
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I did a self-clean session and the oven remained locked way after it completed the cleaning. The error message on the backsplash reads E1- F5-. I am not able to open the oven. What's wrong?
I hit the cleaning button instead of the broiler and the oven lock went in mode so now it thinks it is cleaning but I can't close it and it won't shut off the cleaning mode. What can I do?
Sep 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
Control panel and oven door lock
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
To lock the control panel and both oven doors:
  1. Press and release Cancel.
  2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
  1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Dec 22, 2008 | Jenn-Air Electric Double Oven
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Jun 02, 2008 | Frigidaire Ovens
Locked oven door
try turning off the circuit breaker, resetting the power sometimes trips the self clean latch to operate, youll need to push in the door light switch.(it will have to think the door is closed to operate)
Mar 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door locked
Jun 23, 2007 | Kenmore 30169 Electric Single Oven
Kenmore 33464 / 33465 / 33469 Gas Single Oven Logo
110 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
