Question about Toshiba Satellite P105-S9722 Notebook
My monitor started showing vertical lines, first a few then half the screen. Now, half the screen is black.
  • kd0bga
    kd0bga May 11, 2010
    Have you checked your phase settings?
  • 62 Answers
Your Laptop screen has either too much of Moisture in it or the display circuit at the laptop folding place is creating issue. Please take the machine to Toshiba Service Centre and they will do the needful. Any attempts to fix the problem by yourself will worsen the problem and respond quick.
Posted on Nov 16, 2009
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Vertical yellow line lcd monitor
This is almost certainly get another monitor. They are not worth troubleshooting.
Jun 12, 2013 | ViewSonic Computers & Internet
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out in solving the problem....
May 21, 2011 | Gateway HD2200 LCD Monitor
Screen turned black
your monitor got a hardware problem:
1) the LVDS controler board out of work, only change or repair it could be fixed.
2) if you can see some show like smaller signal detect windows in the centre of screen a very short time (bright flashing one time), this is inverter board damaged or worn lamps, thay all need repair or replace
hope give you some idea. please take a rating let me know how much helped you thanks!
May 20, 2009 | Dell E176FP 17" LCD Monitor
Black screen
It may be repairable, but you will spend less money to replace it.
You did not mention if this is a CRT or a LCD monitor.
If it is a CRT the Rasters and flyback are faulty causing dead areas on the screen.
If it is a LCD then you are having pixels dying, and it will not last too much longer.
You may want to try it on another computer just to verify that it is not your video card.
May 20, 2009 | Computers & Internet
HCL 17" monitor display problem
Hi there ,
It seems that you have a vertical section problem ,It might be possible some capacitor might have gone wrong
Jan 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Shows half screen only!
if you can't expand your screen size from the pulldown menu or vertically or horizontally center the picture one or two of the centering coils could be partially burned out. the monitor uses electromagnets around the crt neck to center the picture. varying the center controls apply or take away voltage from the coils to center the image. may be time for a new monitor
Jun 08, 2008 | Compaq MV 540 15" CRT Monitor
A black vertical line on my screen
it risky if you always use your monitor that has a factory defect..i suggest to return to the store for some replacement of your monitor...coz your monitor has a warranty.
Jan 28, 2008 | ViewSonic G810 21" CRT Monitor
ACER 17" black monitor
first, I would check screen cable. try replacing it with a new one, you will be surprised to know how many display problems are are caused by a defected screen cable. in case this is not the problem, it can get more complicated, but first, just in case, reinstall drivers. its a long shot, but if you get lucky it will save you alot of pain. in case it didn't help, It's probably a bad vertical output chip. if you have some familiarity with monitors and decent soldering skills you could probably fix it yourself, but I would advise looking into taking it to a shop, or at least find an experienced hobbiest if you're not yourself. It's a pretty straightforward fix for someone who knows what they're doing. good luck.
Apr 03, 2006 | Acer AL1711 17" LCD Monitor
Toshiba Satellite P105-S9722 Notebook Logo
222 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
