Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Need to help accessing convergence IC's on Pioneer SD-P5191-k
I am having convergence problems, I am going to try to fix it myself after finding courage with reading through the posts in this site, besides , can't afford the tech estimate of 400 bucks. However I am having problem getting access on the convergence IC's. I have been having trouble because of the tight space and I can't seem to get the A board out, I was able to find the screws to the whole thing, but the cables and connectors prevents me from taking the whole mainboard out. If I could have some guidance on how to get access and how to get the IC's out OR by just taking the whole heatsink without taking out the whole mainboard. tnks
    President:
  • 4,402 Answers
These sites should show you good examples
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Posted on Jan 17, 2008
6ya staff
SOURCE:
I HAVE A PIONEER 50' TV AND THE TV REPAIR MAN WORKED ON THE COLOR CONVERGENCE AND NOW HE SAYS THAT I HAVE TO FINE TUNE IT? the main problem was the blue line.
YOU need to have the original Pioneer remote to do this--I do not understand if someone fixed and you had the remote why he did not adjust it?
With the Pioneer remote you go into the customer menu and adjust convergence--most also have a TECH menu for this but you still need the remote and a code to get into this--REMOTES FOR THESE SETS ARE HARD TO FIND AND EXPENSIVE.
Let me know if you have questions--I am here to help.
If this helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Would anyone know what a screen might cost for a pioneer projection sd-p5191-k
I'm not sure which screen you need so both are listed below:
part number Description Cost
AMR2835 Lenticular Sheet $306.95
AMR2836 Fresnel lens screen $430.95
Hope this helps,
Dan
Jan 19, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Screen cost?
hi my name is Rocky I'am new I live in windsor on their is a person I know here who has lot's of them if you remove your's and bring it to him he will give you the exact one $40.00 I have the same problem but I don't know how to get mine off can you help with this problem thanx rocky
Red convergence bowing
Replace both of your STKs if they are STK392-110s upgrade to STK392-180s these are the convergence ic big black ics 2 of them. Electronix Parts 1-800-223-3205
Dec 15, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Where to buy a convergence ic
This link may help you with the convergence problem: http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
You can just put the search "convergence ic" into EBay and get a list of sellers for the ic's.
Jun 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Convergence
convegence amp ic are bad
Nov 13, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Right side convergence
A convergence IC has burned out. If I remember correctly, those Pioneer sets have one huge convergence IC, but that IC only has 5 channels in it so they use another smaller dual STK IC and one half of it is used for the 6th channel and the other half is the vertical output. Look on the convergence board, find the blue convergence jack, identify the blue horizontal channel, follow the traces and replace the IC handling the blue horizontal channel.
Aug 28, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
SD-P5191 Pioneer control inputs lock after startup
Pioneer say Main CPU bad. Replace and install capacitors, diodes and shield plate. See SI Bulletins for more info.(SI-a48032-G)
Apr 14, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
104 people viewed this question
Top Pioneer Televison & Video Experts
Marvin
Marvin
Ekse
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
