Question about Sony 1GB Memory Stick PRO Duo Memory Card
Memory stick full how do i clean it of **** - Sony 1GB Memory Stick PRO Duo Memory Card
    Problem Solver:
  • 14 Answers
Format the the stick by plugging it into a computer right clicking on the drive and selecting format or opening the drive on the computer and deleting unecessary files.
Posted on Nov 16, 2009
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
I bought a new Memory stick for my Sony DCR-TRV320 Camcorder and when i switch my device to memory mode, it tells me "Memory Stick Error."
Check the following:
Memory Stick is inserted in correct position and orientation in camcorder. Try re-inserting several times.
Write-protect tab is switched to allow writing to memory stick (on back of memory stick)
Memory Stick is formatted in FAT file system (this should already be done except if memory stick has been formatted in a computer in a different format)
Memory Stick is not over the maximum capacity memory stick of the camcorder.
Memory Stick is not full.
Memory Stick is clean and dry.
The dcr-trv320 is a 2000 yr. model and came with a 4mb capacity stick and can probably only use up to a 128mb capacity stick or possibly 256mb. Most memory sticks you can buy today are 1GB, 4GB, 8GB etc. memory stick pro duo. and are probably incompatible. E-Bay has some of the old memory sticks like the 128mb for sale.
There is a slight possibility that static electricity discharge zapped the stick. Try another memory stick or try the stick in another device.
May 02, 2011 | Sony Handycam DCR-TRV320 Digital Camcorder
How to save a picture to a memory stick,,
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Thanks for using FixYa
Dec 04, 2010 | Sony Cyber-shot DSC-T2 Digital Camera
Memory stick error when camera is turned on
Hi
How about download the user manual from this link
http://www.docs.sony.com/release/DSCV1.pdf
and then, please read page 106 and follow the sugestions they have relative to your memory error.
Are you using the correct memory type recommended for your camera?
Did you insert the memory stick in correctely?
Is the metal part of the memory stick and the camera clean?
Did you accidently recorded video for a long time on the memory stick. The memory stick may be full.
Did you unlock the memory stick if it has one?
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 27, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
No Pictures but full card
Sometimes when you edit pictures on your memory stick, it will transfer the files to a different folder. Then the card will seem blank to the camera. Format the memory card using the PC to clean it for good.
Nov 12, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
MEMORY STICK EMPTY BUT CAMERA THINKS IT'S FULL
If you have backed up your files/ fotos, then format the memory stick/ card.
Jun 24, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Memory full message in error
Remove some pictures from the memory stick Or copy them to your computer. Actually your memory stick is full. If you have no memory stick in the cam then purchase a new one for it. The cam memory is not enough to store many pictures.
Mar 28, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
USB drive
What OS are you running? What computer do you have? Which memory stick is it? Have you downloaded music or software on it, or was it given to you by someone and you want to clean it up?
Feb 28, 2008 | Computers & Internet
Please help: readout says "no memory space" but memory stick is empty!
When you copy pictures to your computer you still have the pictures on your camera so there is need to clean them up my reformatting memory stick.   This procedure will leave the memory stick clean and ready for a new set of pictures.  Here is how you reformat the memory stick-:
1.  Insert the memory stick to be cleaned/formatted in the camera
2.  Turn the MODE DIAL to the SETUP position on the camera
3.  Switch on the camera
4.  Select the MEMORY STICK TOOL from the CONTROL BUTTON
5.  Press the centre of the CONTROL BUTTON
6.  Select FORMAT by using the down arrow and up arrow
7. Choose OK by moving the right arrow button
8.  Finally press the centre of the CONTROL BUTTON and this will start reformatting the MEMORY STICK and it will ready for reuse.
Enjoy your new space in your Memory Stick!
Oct 24, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Sony 1GB Memory Stick PRO Duo Memory Card Logo
63 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
