Question about Kitchen Ranges
Frigidaire Model FGF366CCB Temperature
Frigidaire Model FGF366CCB (or maybe FGF356CCB-Label is scratched right in the middle) Oven takes a long time to pre-heat (up to an hour), then won't hold the temp. But inconsistent problem, sometimes it's fine. No apparent problem with display.
aborcass
  • 2651 Answers
SOURCE: oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Posted on Mar 26, 2008
RescueTech
  • 145 Answers
SOURCE: oven slow to heat
An extremely common problem on these models is a weak silicon carbide ignitor. You may be able to see the ignitor glowing, but that is not an indicator of it being functional or not. When the ignitor gets "weak" over time, it will not create enough amperage in the circuit for the gas valve to open. You can test this using an amprobe around one of the ignitor leads and looking for at least 2.9 amps, but years of working on these appliances has shown that if you are getting the glow from the ignition but the oven is often slow to come on, you need a new ignitor. Do-it-yourselfers often mistakenly replace the oven valve or the oven temp sensor, figuring the ignitor must be good because they can see it glowing.
Replace the ignitor and your oven will work great again.
Posted on Dec 14, 2008
TheMobilian
  • 8220 Answers
SOURCE: Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
Posted on Dec 19, 2008
aborcass
  • 2651 Answers
SOURCE: Erratic/slow heating
sounds like an issue withthte ignitor in the oven cavity, part number 5303935066, easy to install comes with instuctions, be careful however teh parts pretty fragile
Posted on Mar 07, 2009
Maytag317
  • 1136 Answers
SOURCE: Oven temperature does not get hot enough.
Hi, It sounds like the ignitor might be getting weak and opening the gas valve conditantly. Try setting a temperature and watch to see the ignitor glow. The flame should ignite within 30-45 seconds. If the flame ignites to heat rith away, it should get up to temp before shutting down.
I hope this helps you. Please let me know if I can assist you further with this issue.
Thanks
Vic
Posted on Jun 24, 2009
Bake element wont cycle the temperature
PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204143.pdf
Note: The oven function will not work if the time of day clock is not set. ... The ovencan be programmed for any temperature from 170°F to 550°F (77°C to ... Can be used with BAKE TIME to program a delayed bake cycle. Timer Pad- Used to.
[PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204125.pdf
cycle. Bake Time- Use to enter the length of the baking time. Timer ON/. OFF- Use.... It does not disable the clock, Kitchen Timer or the interior oven lights. TIMED. DOOR .... The Preheat feature will bring the oven up to temperature and.
Gas Oven Repair Manual - Chapter 6 ' Gas Ovens Manuals
www.appliancerepair.net/oven-repair-6.html
If it does not ignite, you certainly do not want the gas valve to stay open. ... these sensor bulbs do not cycle the burner on and off to maintain oven temperature.
How To Fix An Oven Door That Won't Open After A Self ...
Jan 28, 2016 | Frigidaire Kitchen Ranges
Frigidaire cookstove model no. fgf316wgta oven not getting hot enough
Hello - Does it reach the temperature and then back down, or does it take too long to get to your set temperature? Either you have a faulty element or a bad communication error with the main control board.
Sep 25, 2012 | Frigidaire Kitchen Ranges
Frigidaire Gallery stovetop model number LGEF3031KMB Oven will not heat up to temperature. Oven, Pre-heat lights will come on, but the oven will not reach any temperature set.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Aug 11, 2011 | Microwave Ovens
Oven temperature fluctuates.Oven heats to correct temp on preheat, but as the food cooks the temperature drops.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Nov 17, 2010 | Frigidaire Ovens
Frigidaire Model FGF366CCB. (~5 yrs. old)...Oven-Broiler does not work. Checked the ignitor and it glows strongly, gas valve does not open. What's a good troubleshooting process?,,,
Using amp clamp with the igniter on should 3.2 amps or higher. Change the igniter, even tho it is glowing it is not pulling enough amps. Common problem and will fool you.
Feb 01, 2010 | Kitchen Ranges
Frigidaire Model FEF365BGWE Oven not working, Error F3 on display
I found this:
"F3 - Oven temperature sensor circuit fault
The manufacturer has assigned this error or fault code to indicate that the oven temperature sensor has failed. Test the sensor with an Ohm meter for the proper level of electrical resistance. The sensor is not repairable, if it is defective it will need to be replaced."
If it was me, I'd find the oven temp sensor (long thin metal thing like this: http://partsdr.com/part/5304497424-oven-sensor-kit/ this may not be the exact replacement part) and examine it. Unplug it and plug it back in. Maybe it's just lost proper contact. If not, don't waste a lot of time one it...just get a new one. They don't cost much.
Apr 22, 2017 | Frigidaire PLEF398AC Electric Kitchen...
Frigidiare electric range time bake and self cleaning
F3 The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F3 Oven temperature sensor open Replace oven temperature sensor F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
Nov 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire classic series. model #fgf366ccb. i'm having problems with the control panel and timer. it will not turn on or do anything. all it is showing is 9.
I have the same problem - the panel goes out every now and then. I just flip the breaker to kill the power, then restore it again a few seconds later, and all is fine aga (well you have to reset the clock). :)
Apr 19, 2008 | Kitchen Ranges
Self cleaning oven instructions
I tried pressing clean then the up arrow. Nothing. THEN I HELD DOWN THE UP ARROW FOR A FEW SECONDS AND 3 HOURS CAME UP AND it worked and my oven is now cleaning itself. Remember...HOLD DOWN the up arrow for a few seconds and it will work
May 26, 2007 | Frigidaire FEF352 Electric Kitchen Range
Kitchen Ranges Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
