Question about Vacuums
THE ROLLER IS DRAGGING AND MAKING A NOISE - Vacuums
    Problem Solver:
  • 12 Answers
Your drive belt is probably streched and slipping on the motor shaft. However your bearings on the roller brush may be worn out.
Take roller brush out of power head and check the bearings at each end. If they are siezed buy a new brush.CHeck to see that your brush housing is not damaged due to heat caused by siezed bearings
Posted on Nov 17, 2009
Is there a wrong way to attach the belt and the sweeper?? My Hoover Runabout is making a rubbing noise, like the sweeper is hitting something, and it's real hard to push.
take off the belt . clean any hair from brush roller make sure movement smooth . re position belt and move by hand to make sure roller is not skew , , rubber is riding sideways and causing friction .
Mar 22, 2012 | Hoover Vacuums
I just replaced the clutch on dyson dc07 and it's
Hi there, Yes it likely does need replacing. The only other possibility is that the base plate is installed slightly incorrectly and is pressing on the roller making it unable to move. If the machine makes the same sound without the base plate on replace the roller brush. It is possible to simply replace the roller brush bearing too (size 625) if the roller is not damaged.
Mar 12, 2012 | Vacuums
Dyson DC17 making loud noise
Hi Liz,
I'm sorry to hear that you're concerned about the noise your DC17 is making. It will be difficult for us to help without hearing the noise, so it's probably best if you get in touch with us directly. One of our Helpline experts will be able to determine the cause of the issue, and will be able to recommend the best course of action.
You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 27, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Model #3760-2 Bissell upright vacuum- making very loud noise when running. Cleaned all filters- no difference
Is the noise coming from the belt area, ie. beater bar, or does it sound like it is coming from the motor itself? It is possible there is something caught in the brush roller.
When you turn the roller off, does the noise go away?
Dec 20, 2010 | Bissell Vacuums
DC17 Animal - loud noise in roller bar
We were able to get in touch with the Dyson support people and they told us this model doesn't have a clutch in the roller bar. The support person helped us walk through looking at the vacuum and it turns out the belt was stripped and they are sending us a new replacement belt. Case Solved!!
Oct 05, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Roller turns but makes noise
When you set the roller back in place, you probably didn't get it set in the slots properly. May be raised up slightly on one side.
Jim
Jun 08, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover Wind Tunnel 2 Making Noise While Operating
sounds like your brush roller bearings are going bador cloged up with carpet strands if you can take the bottom open and remove the brush roller look at the ends and see if you see any melted plastic or see if the ends feel loose like wobble back and forth.once you take the roller out turn the vacuum on and see if you hear the same noise.also check the belt and see if it looks burnt on the inside of the belt. and does it look stretched out .the belt might be stretched out and fluttering when running.feel free to cal me and maybe i can help you further with it.i'm not one of the techs .i'm just trying to help people.i don't charge for my advise
Apr 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum Roller making a loud noise
Your roller brush is starting to fail. If you unscrew the ends, you will find a lot of hair wound around the stem. You probably have a warped plastic end the holds the bearing. This is my problem now.... I am looking for a new roller brush as I write this. I found one for $30. Good Luck.
May 11, 2007 | Hoover U5018-900 Bagged Upright Vacuum
Vacuums Logo
79 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
