Question about Toshiba REGZA 47HL167 TV
I HAVE A TOSHIBA REGZA LCD TV 42'',MODEL NUMBER 42HL67US,SERIAL NUMBER AM392010403 AND I CANNNOT HEAR ANY AUDIO FROM THE CHANNELS AND THE TV TURNS OFF ON ITS ON AFTER PROBABLY 15-20 MINUTES OF THE AUDIO BEING GONE.
SOURCE: toshiba regza 42" lcd sound but no video
Holding the power button down for 10 seconds fixed this problem on my Regza 47"
Posted on Oct 27, 2008
SOURCE: black line
Called ghost lines or banding. I researched on toshiba thread LCD screen bad. I have same problem purchased HL196 4/07 problem appeared 1 year and 9 months ago no extended warranty. If still under warranty call toshiba. LCD screen more expensive then orginal price of TV. Should file class action lawsuit for selling defective screens. Lot of people having same problem. goforth2953
Posted on Mar 13, 2009
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
budmrtn
  • 11361 Answers
SOURCE: the picture on my 42 inch lcd toshiba regza has
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 15, 2009
tvtek
  • 1284 Answers
SOURCE: toshiba regza all but the hdmi input on my 42 inch toshiba regza
In most cases the HDMI issues are the source itself. Try another item like a DVD player or BluRay player. If they work then its a compatibility issue. If they don't then the HDMI receiver board in the TV is bad. Please take a moment to rate my answer. Thanks...
Posted on Nov 20, 2009
Why is the t-con board in my Toshiba Reza 42HL67 LCD TV repeatedly dying?
Could be just bad luck! It seems unlikely to me that the power supply would take nearly a year to destroy the T-con board!
You could get in touch with Toshiba to see if there is some kind of problem that is cropping up on this model that might cause failure in on the T-con.
May 19, 2016 | Toshiba Regza 42hl67 42-inch 720p Lcd Hdtv
What is wrong with th sound on my tv. Toshiba 42"
sometimes its the hdmi cable input
to trouble shoot that switch to another type of input . like video an audio cables or channel 3/4
if it still happens then the audio circuit in tv is to blame.
Jan 04, 2015 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Headphones plugged into TV audio output but speakers don't turn off
use the tv's setup menu to set the audio properties,eg. speakers on or off when headphones are plugged in.
Dec 22, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Hi. I have a 42"
The best solution to this problem is to call Toshiba directly and ask for assistance. Any TV repair company/shop will probably charge you an automatic fee to assess the problem, and then tell you it's a very expensive fix. With just the model and serial number of your TV, an easy 5 minutes will get you the answer you are looking for.
May 03, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I cant program any channels on my tv. Toshiba 42'' plasma. Do i need the remote or can i do it directly from the tv?
Which specific model from Toshiba do you have? There are several 42" TVs released with the Regza name. Most of the manuals can be found on the Toshiba support web site. http://www.tacp.toshiba.com/customersupport/
The one that I have allows for the channels to be set from the On-Screen Menu. In the TV mode, press Menu (there is a Menu button on the side of the TV). Navigate with the arrow keys (CH+, CH-, Vol+, Vol-) to the Setup menu and highlight Installation and press Enter (the Menu button is also the Enter key when using the buttons on the TV). Then highlight Channel Program and then Start and press Enter. When the search is done, press Ch+ or Ch- to view a station. To add or delete channels, use the Channel Add/Delete that is one line below Channel Program. Use the enter key to change the check mark status next to a channel. If adding a digital sub-channel not previously found, enter the number manually on the remote using the 100 key to add the dash. If the channel isn't found, an error message will result.
I hope this helps.
Jul 28, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have a toshiba regza model 42AV500A which when I moved it will only tune digital channels, so instead of 14 or 15 channels I now only have 3. How do i reset the tv so I can re tune it?
I Have a tosshiba regza 42" . But when we try to go onto atv it will not let me as its not highlighted and can only get digital. the reason i want atv is to get a spare channel to bring sky through Thanks
Mar 24, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
No Video for my cable tv. Audio works
You have the TV connected to the cable box with an HDMI cable, I'll bet. The problem is with the cable box. If you unplug the cable box and plug it back it it will reboot and proabably work. You should connect the cable box to the TV using component cables and you won't have this problem again.
Nov 11, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Which lead do i need
get a pc cable from your local computer shop serial port to serial port and bobs your uncle
Mar 23, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba REGZA 47HL167 TV Logo
179 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
