Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
I need a detailed head bolt layout for a Little
I need a detailed head bolt layout (photo?) for a Little Wonder walk behind leaf blower Cat. # 9008PI/C. It is powered by an 8 hp Briggs and Stratton engine model 195422 type 1132-01. It was manufactured around 1994. The head bolts are designed to mount the fuel tank, fan shroud and a small right angle bracket so they need to go on in a very specific location.
Thanks
boscia
  • 163 Answers
SOURCE: gap setting poulan wildthing blower
you can use an index card or a manila envelope to set the gap
Posted on Dec 08, 2008
#1 Taper
  • 1041 Answers
SOURCE: How to you repalce a fuel line on a weedeater gb1/22v leaf blower
When replacing fuel line, make sure that you have the correct size lines. Depending on the size of your engine, the lines may vary in size. The primer bulb line will sometimes be larger in diameter than the fuel line to the carburetor. The primer bulb line will be the shorter of the two. When replacing the fuel line, make sure you have enough line to go from the bottom of the tank up to the carburetor. Give yourself a couple extra inches to work with. Cut one end at an angle, this makes it easier to feed down through the hole. Continue feeding the line until it comes out of the gas cap hole. Then cut the end of the line square again and attach the fuel filter that goes on the end of the line. Place the filter back in the tank, then adjust the line so that the fuel filter lays comfortably at the bottom of the tank. Then attach the other end of the line, (where you inserted it), to the carburetor, cutting off any extra line you may have.
Posted on May 23, 2009
SOURCE: Weed Eater Lightweight 1500 Leaf Blower Fuel Line
If you push the bulb and note the port the gas squirts out... this is the short line. The other port should **** up when the bulb is released... this connects to the long line with weighted filter in tank.
Posted on Nov 08, 2009
  • 468 Answers
SOURCE: I can't get my Poulon leaf blower to start
So far everything looks good. You're getting fuel, and you're getting spark. Only problem, is you've gotten too much fuel in it, and need to get rid of some before you can proceed. Take that spark plug out, and pull the starting rope hard several times. This will force the largest amounts of fuel out. Now's the part where you'll have to trust me. Use a match or a lighter to "flash" the cylinder. Make sure you don't have excess fuel spilled over the blower, but hold that match or lighter right up to the spark plug hole, and it'll "puff" at you. Please don't look into the hole while you're doing this. Flash the cylinder, and then pull the rope again, and flash it again. Next, make sure the spark plug is dry then put it back in. Set your choke to full choke, and pull until it hits once. Then put the choke on half, and it should start within 3 pulls.
Posted on Mar 25, 2010
  • 15360 Answers
SOURCE: I have a model BVN200 Poulan leaf blower. I'm
most small engine repair parts stores can carry the part or order one if one is not available made[trace] one out of paper or cardboard and go to small engine or auto parts store and buy gasket material suitable for ur application and make the gasket
Posted on Jul 04, 2011
Can't get a brand new little wonder LB900 blower to start
Needs fuel,air and spark.
Inspect "sparkie".See if there is a spark(when grounded),during start.
If so,is the sparkie fouled with fuel or carbon?
Smell the gasoline.If it's bad,it won't run.
Possible carb problem.(Fuel delivery)
Heat the carb w/a hair dryer. That works wonders!
May 18, 2014 | Little Wonder Lb900-00-o1 9 Hp Honda...
Can't find the oil drain plug
Most small engines don't have an oil drain plug. Open the oil filler cap and flip the unit upside down and let it drain into a suitable container.
Apr 10, 2014 | Little Wonder LB270S Optimax 265cc Subaru...
We have had our poulan leaf blower 7 moths and its been worked on 2 xs and its not starting now and has only ran one time since then im not happy with this and i wont buy another one because it is our...
Some of these small blowers end up with loose cylinder heads! If you can wiggle the spark plug and the whole head moves this may be your problem. When the cylinder is loose it wont move fuel properly into the combustion chamber because it moves up and down a little with the piston. If you want to be able to tighten the cylinder head yourself you need to make a couple holes around the spark plug opening so you can put a 3/16th hex key on the head bolts and tighten them.
The location varys but I usually see them when I make 1/2 inch holes in the cover at the 8 oclock and 2 oclock positions about an inch and a half from the spark plug. If you get the first hole wrong you can just drill another one in the adjacent corner *(its a 50/50 chance you put the hole over the bolts on the first try!) I have blowers that need a tighten every couple months and they run just fine! Check it out! Good luck and be careful!
Sep 29, 2013 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Walk behind leaf blower shuts off when it gets hot
When a failing coil gets hot they quit putting out spark
Sep 14, 2013 | Briggs & Stratton 190cc 875 Series OHV...
Craftsman Leaf blower with new carb won't start
check the head bolts to make sure they are tight
Dec 16, 2011 | Craftsman Garden
Toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Mar 16, 2009 | Toro Lawn Mower With Toro Power Tools
Leaf Blowers types
* Handheld units are the most popular. Available in gas- or electric-powered versions, they're portable and convenient, yet powerful. These models can get heavy while using. Larger models can also vibrate a bit at full throttle. Consider the weight and balance of the unit when shopping. * Backpack leaf blowers are gas-powered. The blower fits in a harness that's worn on the operator's back. The hose reaches to the front where the user operates the throttle and blow or vacuum tube. Backpack blowers are normally used in larger areas. * Walk Behind leaf blowers cover the most acreage. Mounted on wheels, these gas-powered machines are normally the tool of choice for commercial users, but for regular homeowners, they can make short work of a home lawn. Vacuum units use a hose for picking up debris.
Aug 27, 2008 | Toro Super Blower Vac
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
98 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
