Question about Invacare Pronto M51 Power Wheelchair
DOESNT MOVE CHARGED WHEN TURN ON ALL LIGHTS COME ON AND ALL THE GEAR LIGHTS LITE THE CHAIR WILL NOT MOVE THE CHAIR IS PRE 2005 PLEASE HELP
  • 103 Answers
The motors are not getting power. Check to see that the chair is not in freewheel mode. Also check all the wires to be sure that they are connected properly.
Posted on Nov 16, 2009
Battery fully charged chair levers engaged to drive position chair still will not move.. LIGHTS COME ON FLASHING
more info needed, what chair and what controller? is it all lights or just some and if so how many? are there two sets of lights (one for battery one for speed)? with out this info can not help.
I will have a guess and provide the error info for the most common possibility 10 lights flashing "An excessive voltage has been applied to the controller. This is usual
caused by a poor battery connection. Check the battery connections."
If this helps please click the "YES" button to let others know it is helpful.
Sep 27, 2014 | Health & Beauty
Help me with a merit 4.2 no book,
Turn chair and lights off when charging. The charger and chair will indicate with lights when charge is complete. All lights in full green and display showing full means you are done charging.
Aug 17, 2012 | Health & Beauty
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
May 25, 2012 | Jet 3 Ultra Power Chair
CHAIR IS CHARGED UP BUT WILL NOT MOVE
ajnss I need more information. can you turn the power on at the joystick? are you getting all the lights for battery level lit? are any of the lights blinking on the joystick? do you hear a clicking noise when you try to move the chair? Give me as much info as you can thanks
Feb 05, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Do not know if chair is taking a charge lights just keep moving across armrest .how do u tell when fully charged?
hi let me see if i can help ,
When the lights go back and forth on your joystick that means the chair knows its pluged in .Now the chair itself has a built in charger that is mounted on the back of your chair .The back of the chair ,there is a opening a cutout in the frame .when you plug in your chair there will be a red light and a yellow ,yellow means the chair is charging, wait till it turns green,this means fully charged.When you plug in the chair youll see the lights through that hole.Look for the lights.
I recommend my customers to leave there chair charging over night look at the light it will be green when you turn the chair on the joystick should show fully charge.
Good luck hope i was of some help.
Jan 20, 2011 | Invacare Supply Group Invacare Pronto M51...
Battery fully charged chair levers engaged to drive position chair still will not move.. Jazzy 600.... Tried unlock/lock tried putting it in neutral back in drive with levers still wont move please...
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
Dec 20, 2010 | Pride New Jazzy 600 Power Wheelchair by...
I have an Aspire 18 04, model K0011. The batterey indicator lights show fully charged but when you turn the chair on all the lights fliker real fast and there is no response or sound being made when you...
Dave did you check to make sure you are not in freewheel. If you can push the chair easily then you are. Even having one side in freewheel will cause the flashes. Move the levers to drive mode that are on the back of the motors then turn the chair on and see if it works Hope this helps Also make sure the charger is still not plugged in.
Sep 08, 2010 | Health & Beauty
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
My battery is charged and all the lights come on but chair will not move. I cant get it to unlock
Of course it could be a major mal-function- but not likely.
I'm sure you've already checked to make sure the chair is in-gear. That is the levers near the rear of the chair. If you can put your hand on the chair and push the chair, it's not in gear. When in gear you won't be able to push it.
Just because the lights are coming on does not mean the batteries are good. If the chair has been sitting for a while you'll probably need to replace them.
Aug 12, 2009 | Jet 3 Ultra Power Chair
The battery is charged but the lights just flash and chair doesn't move
Make sure the charger is unplugged from the chair and that the chair is in gear. There's two levers that place the chair in freewheel, or neutral so you can roll it around. Place these in neutral, then back in gear firmly. If still flashing, turn chair off, wait three seconds and turn back on, then push on the horn button three times. This will take it out of sleep mode. Still not going, you will need to check all clip-on connections to make sure they are tight.
I am assuming that all of the lights are flashing constantly. If it flashes a "fault code", you will get a series of flashes from 1 to 10, then a pause, then a set of flashes. Count the number of flashes and it will tell you what the fault is for that number of flashes in the owners manual. If it is just two red lights flashing constantly, you have a set of dead batteries.
Good luck.
Jul 11, 2009 | Pride Jazzy Select 6 Indoor Power...
Invacare Pronto M51 Power Wheelchair Logo
197 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
